Transmission & Drivetrain Gearboxes, Differentials, Clutches
gsr trans help
Old May 22, 2011 | 07:44 PM
luis_ej8's Avatar
Default gsr trans help
hey guys i just got my car its a 96 ek coupe with a gsr swap b18c the problem is that you cant start the car in neutral and then go you have to start the car in first gear then the only way to get out of first is to be in high rpm but with no clutch? does anyone have an idea on what it could be..tomorrow in replacing the slave and master cylinders
Old May 22, 2011 | 09:53 PM
AJ3387's Avatar
Default Re: gsr trans help
more than likely you are having the same issue i had a few years ago, i had the start the car in gear and the started would wheel me out of the driveway untill i could get it to higher rpm to power shift (shifting with out using the clutch) and it ended up being a faulty slave cylinder, hope this helps
Old May 24, 2011 | 09:59 AM
luis_ej8's Avatar
I just changed the master and slave cylinder yesterday and still nothing
Old May 26, 2011 | 07:52 PM
dezyred_temperz's Avatar
so you cant select gears without revving the engine up high?
Old May 30, 2011 | 07:12 AM
luis_ej8's Avatar
I would have to be in high rpms to shift but I got the car running the flywheel was shot so it wasn't engaging
JDM_nUt
Jul 8, 2010 01:10 AM
turbo66000
Aug 26, 2008 05:43 AM
jimmyfloyd182
May 7, 2007 07:41 PM
BrokeAssWhiteboy
16
Sep 29, 2004 09:44 AM
982drLS
Jun 12, 2004 04:44 PM
