crx b18a1 block b16 head. help?
i have a 91 crx si with a b18a1 block and b16 head. It has no charcoal canister. The timing belt is lose. The rear springs are broken. It has no corner lights. and its missing the speedo sensor. I found a 92-95 charcoal canister. would that work? and where could i find a speedo sensor? i found some rear coilovers. and i need to know what timing belt to use. Thanks!
The speed sensor is most likely a cable setup unless it has been changed over to a different instrument cluster. I do know that most ever honda charcoal canister does the same meaning. so yea i would think that one would work,
hybridb18
Feb 18, 2004 07:40 PM
