Attn: Any auto mechanics or car whizzes here? Need help!
Old Sep 30, 2002 | 11:33 AM
dolemite77's Avatar
Default Attn: Any auto mechanics or car whizzes here? Need help!
I just took my 1990 honda prelude si into the shop (EconoLube) to get some work done. They were to replace the two front CV Joints, change transmission fluid, and change a couple belts under the hood. The reason for changing the belts is that there was a fairly loud squeaking noise coming from under the hood especially when i was in idle. This was gonna be $600....
So we agree and tell them to go ahead... One of the guys calls back in a couple hours and says when they were changing / taking off the belts, the "Harmonic Balance broke loose and fell to the floor." He goes on and on about what it is, what it's connected to, and then tells me it's gonna be an extra $250 for parts/labor to fix this. Does anyone know if this sounds legit?!? Damn, pretty soon it's not gonna be worth the cost of fixing! I am so fustrated, the total will now be over $900... Any suggestions??
Old Sep 30, 2002 | 11:38 AM
prelude1897's Avatar
Default Re: Attn: Any auto mechanics or car whizzes here? Need help! (dolemite77)
Guess what man, you're getting FUCKED
Old Sep 30, 2002 | 11:40 AM
dolemite77's Avatar
Default Re: Attn: Any auto mechanics or car whizzes here? Need help! (prelude1897)
Yea, i pretty much figured that much, thanks... Can you elaborate please? Do you know anything about the 'harmonic balancer'?
Old Sep 30, 2002 | 12:29 PM
Honda318dx's Avatar
Harmonic balancer is sealed inside the block, at least on Hseries motors it is.. I call bullshit on this one, randomly show up and ask them to show you where it fell off...
Old Sep 30, 2002 | 12:43 PM
satan_srv's Avatar
Default Re: Attn: Any auto mechanics or car whizzes here? Need help! (Honda318dx)
There's Harmonic "Dampener" on the H-series crank pulley...did they drop your crank pulley? If it fell how is it your fault such that you have to pay for it?
Old Sep 30, 2002 | 12:49 PM
DirtyLude's Avatar
Default Re: Attn: Any auto mechanics or car whizzes here? Need help! (satan_srv)
The crank pulley and the harmonic dampener are the same thing. On the late model Preludes the crank pulley happens to also be a harmonic dampener so the term can be used interchangably.
What they are saying is that your crank pulley was loose, or not bolted on properly, or something to that effect, or even that the rubber spacer has seperated the two halves of the pulley. All these things seem unlikely to the point where the pulley would just drop off.
Old Sep 30, 2002 | 01:04 PM
Boostless97Lude
Guest
Posts: n/a
i'm fairly certain that the harmonic balancers are internal on B21's and old school B20's as well. i call bullshit, BIG TIME, tell those guys that if something "fell to the floor" that they have to replace it b/c they dropped it, and that's what made it **** up.
if push comes to shove, tell them you will have your lawyer contact them and see what they say!
Old Sep 30, 2002 | 01:51 PM
DirtyLude's Avatar
Default Re: Attn: Any auto mechanics or car whizzes here? Need help! (Boosted97Lude)
Actually now that I reread the original post, I'm pretty certain none of the 3rd Gen motors had harmonic balancing crank pulleys.
FYI, there's no such thing as an internal harmonic balancer. I'm not certain what you guys are thinking about, but it's probably the balance shafts, which are different.
Old Sep 30, 2002 | 03:17 PM
Chiovnidca's Avatar
Default Re: Attn: Any auto mechanics or car whizzes here? Need help! (DirtyLude)
Not all that unlikely. I see two or three a year that come in with the two halves seperated. They are usually accompanied by a complaint of a noise or the battery light is on.
Old Sep 30, 2002 | 03:34 PM
Boostless97Lude
Guest
Posts: n/a
that's actually what i meant, H22 have 2 harmonic balnce shafts
Old Sep 30, 2002 | 04:54 PM
Chiovnidca's Avatar
There is a difference between balancer shafts and harmonic balancers. They are not the same thing.
Old Oct 1, 2002 | 07:54 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Attn: Any auto mechanics or car whizzes here? Need help! (Chiovnidca)
i know that, i laready said that, but i meant that... you know what nevermind...... i didn't think that older preludes had a harmonic balncers, i thought they had shafts like the H22, i've never worked on one of those, but i've seen pics..... regardless , i think someone is probably getting scrwed on thsi deal
ABCVTEC
Sep 7, 2010 09:05 AM
Bro. Darkness
Mar 1, 2010 06:40 PM
Pharcyde
Aug 18, 2004 01:47 PM
ramz7887
Aug 14, 2003 07:28 AM
dolemite77
Oct 1, 2002 04:41 AM
