D16Z6 Miss fire at idle.
Old May 20, 2011 | 11:32 AM
singlecammin's Avatar
Default D16Z6 Miss fire at idle.
i have a 95 civic with a d16z6 (unknown miles) but its misfiring at idle. it feels like a constant vibration. and pressing and depressing the brake pedal changes the idle. any help?
Old May 20, 2011 | 11:46 AM
H22AFerio's Avatar
Default Re: D16Z6 Miss fire at idle.
Throwing any engine codes? If not Check plugs, wires, Cap and rotor. those ok do a compression test to make sure its up to par.
Old May 20, 2011 | 11:48 AM
Dizzy cap plugs wires all 3 months old. all Oem honda and NGK. Compression is around 192 all cylinders. and no codes. the cel bulb is there. i unplugged the TPS to make sure it actually worked.
Old May 20, 2011 | 12:10 PM
H22AFerio's Avatar
hmm so you have done a bit of trouble shooting. have toy tested your oxygen sensor to make sure it is still working correctly? I wasnt throwing a code for mine but it was faulty and making my car run uber rich untill I swaped it out. Also a plugged injector could cause similar problems.
Old May 20, 2011 | 12:12 PM
Originally Posted by H22AFerio
hmm so you have done a bit of trouble shooting. have toy tested your oxygen sensor to make sure it is still working correctly? I wasnt throwing a code for mine buty it was faulty and making my car run uber rich untill I swaped it out. Also a plugged injector could cause similar problems.
its running very rich. ive never tested a o2 sensor. i really dont know how
Old May 20, 2011 | 12:15 PM
H22AFerio's Avatar
here ya go
http://www.ehow.com/how_5544442_chec...n-sensors.html
or you can go pick one up or barrow a buddys make sure you pull the ecu fues for 30 sec so the ecu will reset and can re learn everything again.
Old May 20, 2011 | 04:02 PM
hondatuner34602's Avatar
also u might wanna check if u got good gas sometimes people forget check those things. when the last time you change the fuel filter? a clogged filter can cause that kind of a problem
Old May 20, 2011 | 05:17 PM
H22AFerio's Avatar
Thats true also, none of that arco **** they water their crap down with ****. I only do Shell or chevron.
Old May 24, 2011 | 03:16 PM
Fuel filter is new. I always use shell gas. Replaced o2 sensor it helped with the running rich. I did somemore testing when I turn the air conditioning on it smooth out some but its still there. When I depress the brake it starts to idle like the iacv is bad. Which the iacv is also new. My brakes go to the floor and hardly stop. I also have a new brake master cylinder which after I replaced it I bled the hell iy of them. Maybe a vacuum leak in the brake booster?
Old May 25, 2011 | 05:40 PM
bump
Old May 26, 2011 | 01:41 PM
help?
Old May 26, 2011 | 02:08 PM
H22AFerio's Avatar
Your idle could be low also what are you idling at? are you running a stock P28 man?
How to Adjust Idle
http://garageninja.com/idle-speed-mi...-1992-1995-eg/
Old May 26, 2011 | 02:21 PM
it is idling low ive tried to raise it. but nothing seems to work. and as far as i know its a virgin P28.
Old May 26, 2011 | 02:27 PM
H22AFerio's Avatar
Well follow the steps in the walkthrough I posted for you and you will be set. also how is the timing on your dizzy? is it set in the middle or is it tilted to the firewall or tilted to the front of the car. put it dead center or little to the front until you can check the timing light.
Old May 26, 2011 | 02:58 PM
timings dead on i checked that when i replaced my dizzy and the dizzy in in the middle. i just did the walk through. its right at 650, still shakes and stuff. im about ready to push this car into the tennessee river and laugh as it sinks lol i also noticed as i was doing this it had the occasional miss while i was holding it at 3k rpms....
hardeeboy
Nov 30, 2009 09:57 AM
hmtcrxsir
11
Aug 18, 2007 08:01 PM
92civeg
Feb 19, 2006 05:55 PM
AThiker
Mar 19, 2005 09:50 PM
Efil4zaggiN
Dec 17, 2004 07:32 PM
