Differential bearing swap?
I have a stock GSR diff with tapered roller bearings. I was seeing if I can saftly swap the tapered bearings to the LSD I have
Also if that doesnt work, the LSD came with the bearings that we all are use to.. dont know what the name is, but is there a way to convert the housing for these to fit is the top question wont work?
You can use tapered roller bearings, but you need special tools to set the preload on them, it's much easier to just use the enclosed ball bearings instead.
raverx3m
Transmission & Drivetrain
21
Dec 13, 2014 11:46 AM
TB123
11
Apr 12, 2009 11:06 PM
Nameless RB26
Dec 15, 2002 12:10 AM
