issues with swap.. help please?
Old May 19, 2011 | 07:03 AM
Boostdprotegelx's Avatar
Default issues with swap.. help please?
So a friend of mine blew his motor. He has a 1996 honda accord 2.2 auto with the f22b2 motor. I did a motor swap for him except the motor that he bought was an f22b.
It didn't come with a crank sensor so i pulled the timing covers off to install one, but there's no spot for it.
From what i understand the b uses a crank sensor in the dizzy..
so when i go to start the car, it cranks, but won't fire. the dizzy i used is from his b2.
Can anyone help me to figure out what i must swap/ do to make this car run, please?
Thanks a ton!
Old May 19, 2011 | 09:21 AM
SQ is the SQUAD's Avatar
Default Re: issues with swap.. help please?
you are going to need a crank sensor so you got 2 options. figure out some way to get it on the crank, or use the other dizzy and bypass the plug to the signal coming from the distributor crank sensor.
its a very common bypass trick dont on civics and integras.
Old May 19, 2011 | 10:13 AM
GhostAccord's Avatar
The Non VTEC JDM F22B = F22B2, difference is that the JDM F22b is OBD1 and has the TDC and CKP sensor in the distributor. USDM OBD2 F22B2 have the 2 sensors mounted to the oil pump housing. This is a very well documented issue.
Wire the TDC and CKP using the F22B distributor or you could swap the OBD2 oil pump housing, and both crank gears (timing and balance) Without these tow gears the sensors will not work ether.
Old May 19, 2011 | 11:02 AM
Any info on the wiring?
Old May 20, 2011 | 07:47 AM
Can you provide me with info on the dizzy rewire? And can i still use the stock harness? Swapping the oil pump and gears seems way harder and time consuming.i need a quicker fix.
Thanks
Old May 20, 2011 | 08:11 AM
Yeah that oil pump and gear swap is best to be done prior to dropping the engine in.
Give me a bit I think I had a wiring diagram for the OBD2 to OBD1 TDC & CKP sensor swap.
Old May 20, 2011 | 10:16 AM
that's awesome. thanks man. i CAN do the gear swap and w/e. but I would rather an easy solution..
would rewiring the dizzy allow the ecu to "read" a crank sensor some how?? how would that work?
Old May 20, 2011 | 10:20 AM
As long as it is an OBD1 F22B distributor equiped with TDC/CKP/CYP sensors. AFAIK The CKP sensor that is in the OBD1 distributor sends out the same signal as the CKP sensor that is located on the oil pump housing of the OBD2 F22B2.
IIRC the OBD1 distributor should have 4 extra wires.....2 for each of the sensors.
Old May 20, 2011 | 06:13 PM
ok and do you know WHERE they wire to? and also, what about the plugs, as they are different.
Old May 20, 2011 | 06:32 PM
Honestly. myself, I would by a new 4/6/8 pin weather proof connector, that has both sides and new pins and solder in the new connector. However you may be able to get an OBD1 connector from the junk yard that will fit easy enough.
Here is the wiring, even though it says F22B1 the wire descriptions/colours are the same for the F22B2.
by GhostAccord, on Flickr
The CKP and TDC wire harness (WHT - BLU & GRN - RED) should be part of the original engine harness. They would be found over on the cam gear side of the engine. The wires will be more than long enough to reach the distributor. You will need to unwrap the wire loom and pull the 4 wires out. Then wrap it back up.
Old May 20, 2011 | 07:33 PM
ahh good stuff.ok. thanks so much. i'ma give this a shot.. so basically if this works, the car will start, i dont need the crank sensor that i just paid 185.00 for?
Old May 20, 2011 | 08:28 PM
Nope!
Old May 21, 2011 | 06:34 AM
yeah i just thought about something.. am i using the b2 dizzy? or the b?
Old May 21, 2011 | 08:40 AM
You Need the OBD1 distributor with the three sensors inside it. So that should be the F22B.
Old May 21, 2011 | 04:00 PM
ok. thanks ghost, idk WHY i went retarded for a minute. lol
Old May 22, 2011 | 10:14 AM
Hey ghost.what about the dizzy cap? Theyre different.one has 4 holes for plugging one has 5..the b2 has 5 the b has 4
Old May 22, 2011 | 11:02 AM
That ia because the OBD1 distributor has an internal coil and the F22B2 OBD2 has an external coil. You will have to swap to an internal coil as well. Sorry forgot to mention that I assumed that you already had that done. If you can get your hands on an OBD1 H23 distributor I think that has the internal sensors and it is an external coil so you won't have to convert to internal. However you will still have to do the sensor swap.
There has to be info on this swap in a DIY or swap thread already.
Old May 22, 2011 | 04:50 PM
well i went ahead and just put the b dizzy on. and didn't swap the coil.. it worked perfectly fine.. idk car starts up every time.. do you think there might be issues with this?
Old May 22, 2011 | 07:41 PM
Do you have the CKP or TDC sensors hooked up........ Have you tried to drive it yet?
Old May 23, 2011 | 06:26 AM
yeah it drives and starts. they're hooked up!
Old May 23, 2011 | 01:39 PM
I'm lost, but at least you got it running.
Old Nov 5, 2011 | 06:13 PM
Dracco's Avatar
K I'm doing this swap right now!!!!! It hasn't been fun....I have 2 plugs on my 1996 Accord F22b2 distributor and 2 plugs on the ODB1 F22B they both have a blue and yellow/black wire and the harness is the same do i connect it???.....also i connected the 6 wires in the diagram but am still left with 2 wires what do i do with them?? Also I want to use my external coil....help me please
Old Feb 19, 2012 | 04:10 PM
Kasoan's Avatar
Ghost Accord Many thanks for the diagram here solved my problem so very nicely. since the fix the civic/teg users dosent work on the f22b2.. i tried. this worked very well thx much
Old Feb 19, 2012 | 06:30 PM
You are welcome, glad it helped you!
Old Jul 22, 2012 | 02:32 PM
BRADY-CD7's Avatar
sorry guys, I know this is an old thread and a common problem, but I have already re-wired CKP and TDC sensors on my "97 EX (went from F22B1 VTEC to JDM F22B VTEC) and I still can not get it to start.... I don't think my fuel system is pressurizing either... I feel like a huge noob, but my mechanic can't be bothered to help, and my car has already been down 3 weeks while I did the swap myself...
