How to differentiate between a b16 / itr
I might be picking up a itr tranny and besides from the obvious like the stock itr LSD how would u tell the difference between the two? Would u need to open it and look at the inside? If u do need to look at the inside what are u supposed to look for once it's open? I don't wanna put in 800-1000 dollars in for a b16/gsr tranny and think it's an itr lol
internally a B16 is the same ratios as a USDM ITR. They're actually the same part numbers too. GSR ratios are a little different you have a longer 2-5 gears but same 4.4 final.
But they should be stamped on the bar code (by the torque mount) the trans code. Also, it won't have an LSD equipped.
S4C are usdm SI B16 trans
S80 are ITR
Y80 is GSR
But, just making sure you know how to spot the LSD, just look through the axle holes. If you see hollow tube it's got an LSD, if you see a bar in the middle of it you have an open diff.
If you can open up the box and count the teeth. You count teeth on one gear, divide by the other and that gives the ratio. Make reference to a table that you can search up showing gear ratios.
I guess I should probably ask, what is the person "claiming" this trans to be? USDM? JDM?
S80 are ITR
Y80 is GSR
http://www.ff-squad.com/tech/temp/Bgears.htm
http://hondaswap.com/reference-mater...n-specs-29132/
I'm honestly getting tired of posting this stuff. It's all readily available info guys. Do 5 seconds of research before you make a thread.
Last edited by Billy Elliot; May 20, 2011 at 04:17 PM. Reason: I like when I spell standard "stand"
http://lmgtfy.com/?q=b+series+transmission+specs should be the stand response to threads like this.
NatrulyAspirated
Jan 24, 2011 12:35 PM
JordanCivic
Jul 1, 2005 01:55 PM
