Worth swapping b16 tranny for ITR in built b16 turbo??
Ive just snapped the clutch arm on my b16 turbo, i have been offered a ITR one with LSD, but it aint cheap. My Q is, would i benefit on my setup?? Built b16, peakboost, 16psi.
As an example, if i am running 13.0 ET with my original B16 box, what would be possible with the ITR under the same conditions?? I know its a bit of a ridiculous question, sorry.
Re: Worth swapping b16 tranny for ITR in built b16 turbo?? (JordanCivic)
B16 and ITR gears are exactly the same. If you want an LSD get a better quaife for cheaper than the ITR trans, end of story.
Re: (JordanCivic)
well the gears are the same but it depends on the year of it but some itr trannys have a different f/d.
i dont know how much power you are making and if it is a street car or not but if i were you i would keep the b16, get a quaife, and get new brass and bearings while you had it all apart. just my opinion
