idling problem!!
Old May 17, 2011 | 04:13 PM
whiteEM1's Avatar
Default idling problem!!
i have a 98 ek coupe
i have an idling problem....when my car is in idle it idles from 2000-1000 rpm
keeps jumping up and down through that rpm
WHAT COULD BE THE PROBLEM??
anyone may have an idea on what can cause my car to do that??
need help
thanks
Old May 17, 2011 | 04:18 PM
grumblemarc's Avatar
The Grumpiest
Default Re: idling problem!!
Common problem. Did you try a search? Look up IACV.
Old May 18, 2011 | 08:01 PM
whiteEM1's Avatar
bump!!
anyone else would know what could cause this problem??
Old May 23, 2011 | 10:55 PM
whiteEM1's Avatar
bump!!
Old May 24, 2011 | 07:16 AM
EGgmannate81's Avatar
IACV. Clean it and check the pins in the plug. We sometimes run into a bad connection and occasionally some idiot has hacked the wiring and tried to fix it. I saw a how to thread on here somewhere showing how to clean or replace the IACV. If its not that it could be fast idle valve. Try adjusting this.
Old May 24, 2011 | 07:53 AM
moddedright's Avatar
The IACV has two bolts on the back of the intake manifold. Take it off spray brake cleaner in it, let it dry, put it back on. If that doesn't work I think its a vaccum hose leak. There is one on the back of the intake manifold that is easy to miss, but when I left it off, my car ran just like that.
Old May 24, 2011 | 01:49 PM
Barrera_D16z6's Avatar
I had the same **** happening with my EG after I removed the catalytic converter. I replaced the IACV & it stopped. If I was you that's where I would start....
SoB NiG
Jan 21, 2010 07:23 PM
Civicman86
Aug 4, 2007 01:20 PM
Out of every "game"
Feb 8, 2006 01:12 PM
Shmolie
Jun 29, 2005 05:58 PM
b18c195
Dec 20, 2003 03:39 PM
