Looking to do a SWAP
Hey guys, right now im driving a 1999 civic ex coupe (145kMiles) and i was told before instead of dumping money into turobing my D series i should do a "swap" and people mentioned before swapping with a LS B18, will that "fit" into my car? if i do that swap and how should i find one of these LS B18's with low/no miles ect, if i swapped to a B16-18 would it be better for turboing/faster? Where do i find a new engine to do the swap thats trust worthy and such.
Thanks guys
Hopefully can answer some of my questions
Thanks guys
the LS B18 will fit in your car with a mount kit. And you can find the JDM B18s with low mileage on CL, ebay, or the FS threads on here. or http://hmotorsonline.com/
And you can turbo your d-series. I've never dealt with a sohc myself, but i hear they are good little turbo motors. And you will probably get some good responses on here about the turboed d-series. It always comes down to your budget and power goals. But to answer your swap question, yes, a b-18 will easily swap into your car. You just need to get the whole swap, wiring harness, ecu, linkage, motor/trans and mounts.
I feel like with turboing my D series it will need more like..work/mods/changes for the D to handle a turbo? Cause right now its basically all stock, it would be great to just throw on a turbo with a few other mods but i feel like i need to change A-LOT of things for a turbo to work safely.
