crank pully notches
Old May 17, 2011 | 08:00 AM
76 camaro car's Avatar
Default crank pully notches
Do you use the single notch or the 3 notches on the crank pully to set the timing by? Thanks
Old May 17, 2011 | 08:34 AM
granny racer's Avatar
Default Re: crank pully notches
you use the single notch to set the mechanical timing. and the 3 notches are for the light gun when you set your ignition timing.
and while i had my head off i was watching the pistons to visually see when piston #1 was top dead enter. so i was going to eyeball the piston to see if the marks wher off a little, and once i eyeballed that piston to the most center point as i could
i looked at the mark on the cover and it was dead center in the mark so............
the timing marks DONT lie.
Old May 17, 2011 | 08:12 PM
nus_dogg's Avatar
x2!
thecorey
Feb 21, 2011 05:12 AM
1990si
Aug 7, 2006 12:34 PM
atmdc
Jul 28, 2006 08:34 AM
jonnybebad
Feb 20, 2005 08:34 AM
echo999
Jun 9, 2002 07:39 PM
