4.7 final drive?
hey guys i just want to ask what 4.7 final drive means. and what is the diff between a non-lsd tranny and a lsd tranny.
cause im buyin a b16a with type r cams, type r valve springs, type r red valve cover, intake manifold, injectors, throttle body and distributor. and SiR non-lsd 4.7 final drive........ can you guys explain to me what 4.7 final drive is? is that a good thing or bad thing?
thankyou ^^
thankyou ^^
Don't you mean 4.78 final drive? That's the jdm type R final drive. I think ctr's had it too, but I don't know if it was only jdm ones. It's just a shorter final drive, meaning the motor will accelerate each gear quicker than say a 4.4 final drive. The non lsd part is the bad news. It means the differential is NOT a limited slip differential or lsd. Non lsd diffs spin one tire and lsd will spin both, giving better traction. So you have a tough one here, the 4.78 is a good find, but the non lsd isn't!
for comparison (and i hope i'm remembering correctly..) DX manual civics have a 4.105; EX manual civics have a 4.25. the higher the number the shorter the gear/quicker the acceleration/higher the torque multiplication/the more it's "geared down"... however you want to say it. and when you hear muscle car guys or off-roaders talk about axle ratios or the "rear end" that's the same as the final drive in our transaxles. although their axle ratios are usally some where in the 2.5-3.9 range.
ohhman thanks a lot guys!! great help ^^ and can i ask how youwould get a higher final drive? like whats the best tranny for lets say a jdm gsr b18c and sorry for soo much question guys im jus new to cars. but thanks for your help ^^
Clarify higher. Lower numerically is a "higher" or taller ratio, higher numerically is a "lower" or shorter ratio. So for example a 4.4 to 1 is a higher ratio than a 4.78 to 1.
I'd vote the latter
we're trying but there is no such thing as the "best" transmission.
do you want the shortest geared or "quickest" (debatable) transmission or one that is geared in the middle? maybe even an LS long geared tranny?
what do you plan on doing with the car and how do you plan on driving it?
a B16 and ITR trans is better for city driving and tracks but take that thing to the freeway (especially with the 4.78 FD) you'll get a nice 4500-5000 RPM at 75.
