going b18b into an 88 crx hf
ok, can anyone who has done this swap before, warn me of any problems, and what tranny should i use? Down the road, i want to turbo it. From my searching i have found that i'll need the b18b out of a 92-93 teg? yes no? and axles out of a 91-93 teg? Also, what ecu should i use?
thanks
thanks
thanks
thanks
it's so straight forward..
no wiring mods needed...
just get a bolt in kit for b series...
you can use any LS longblock as long as you use 90-91 dist, ecu and axles....
if you're going to go turbo use a 90-93 LS tranny....
edit: for Hf you need to change your hubs to dx or si hubs....
[Modified by XtraFastCRX, 5:20 PM 9/30/2002]
ok, so here's my list of things i'll need. please correct everything that is wrong:
integra b18b out of a 92-93 LS
mount kit
the same tranny that came out of the car i'm getting the engine from
90-91 dizzy, ecu, and axles
and dx or si knuckles
anything else i'll need, or want down the road?
thanks once again
EDIT: anyone have some dx or Si knuckles they wanna sell me?
[Modified by civicmark, 2:39 AM 10/1/2002]
mount kit
thanks once again
