Slow gsr??
Ok heres the deal i have a gsr swapped del sol running a p28 intake and headers. It seems to run pretty good and hits vtec hard but it feels like it has no power untill it hits vtec. and sometimes at idle the car will die. for example on how slow it seems. my buddy with a mini me hatch beat me by abt a fender he has intake headers full exhaust any ideas what might be causing this ?
If he was and did not hook up the butterflies correctly. He could be on the long side of the intake thus making torque and killing his top end. (although you would have to keep the flapper back by wire or something to do this.)
What I mean by hooking up the butterflies, keep them on the short side instead of the long side.
You should also check your timing. Leak down test too, to see if the motor is hurt.
O sh*t i meant to say p72 lol my fault!. yes it is throwing a cel but autozone said they wont cant check any cars that were made before 95. And about the butterflys. i have vtec and it hits hard but i dont have any power before vtec.
I think the reason you have no power is because of the Butterflies. If you do not wire them, they are on the short runners, making horsepower and not torque. That's why it is a dog out of VTEC. That's my thinking.
Why can't you check your own code?
++++++I'm guessing you didn't wire the knock sensor either which is pulling a lot of timing out of the motor. No POWER.
Check the codes_report back.
yeah you will have no ***** down low if you have the secondaries wide open they need to be wired up. pull your codes and start from there If your throwing a code you might be running in limp mode and thats why your buddy beat you cuz your fuel maps are pretty much cut in half to protect your motor from damaging itself. So pull the codes and get back to us. you need to jump the plug on the passanger side kick panel.
Pulling codes on 92-95 Honda Civic Read up
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
ok so i just unplugged the knock and took it down the road and i acually had some power too it. why is this? and is it bad to run with it unplugged
its bad to run it unplugged when you dont have it disabiled with a chipped ecu. I would be more concerned that he didnt wire up the knock sensor and get the oxygen sensor hooked up it will run like **** with that unpluged. until you get it fixed I wouldnt run anything below 92 octane.
knock sensor is "C3" make sure you have a wire in that slot if not he didnt wire it up. Also check the TPS at "C13" just to be sure the wiring is not fvcked
If you have never dont it before witch it sounds like you havent here is a walk through on how to de-pin ecu plugs good luck.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-depinning-ecu-plug-1573760/
thanks alot! i wired up the knock and fixed the tps and the car seems to really run better, now the only code im throwing is
41-Primary oxygen sensor heater
the only problem with that is i dont have a spot on my headers for an o2 sensor and idk where the connector is to even plug one into? the only free connector i can find in my engine bay is back near the tps
No problem man I'm glad to hear that.
the oxygen sensor plug on the civics is on the front by the temperature sensor. but if the person that did the swap used the gsr harness its gonna be near your mid shaft on the rear of the engine.
the plug looks like this
and here is where it plugs in on a gsr header assuming that it is a stock exhaust manifold good luck!
the oxygen sensor plug on the civics is on the front by the temperature sensor. but if the person that did the swap used the gsr harness its gonna be near your mid shaft on the rear of the engine.the plug looks like this
B18cRuNNer
Apr 15, 2003 12:43 PM
