Quick electrical question
Old May 15, 2011 | 06:38 PM
jtwellner's Avatar
Default Quick electrical question
I am working on some wiring for my b series swap in my 89 CRX. I did some wire tucking and moved some stuff around etc. I don't have the motor in or anything but figured I would power on the system to make sure I didn't have any shorts or draws. Problem is my basic understanding of electricity doesn't help know if I actually have a draw that's a problem or one that is suppose to be there. With the battery connected my seatbelts click like something is being powered on in them. Is this normal? Also I have concluded using a test light that there is draw from a 10amp fuse labeled "STOPHORN" and a 10amp fuse labeled "HAZARD" in the fuse box under the hood. Long story short, should there be draws here and how much?
Old May 15, 2011 | 08:54 PM
MarkOlson's Avatar
OG Hot Rodder
Default Re: Quick electrical question
You should pull out each fuse and put an ammeter across it to see how much current is being drained. I don't see how you can tell this from a test light.
The HAZARD fuse powers the Hazard lights and the ECU. There should be a small draw if your ECU is connected. But it shouldn't be much draw at all, no more than a few mA of current.
The STOPHORN fuse only powers the brake lights and horns. Unless you are pressing on the horn or brake, there should be no current draw.
dansaleen_04
Jul 22, 2013 11:19 AM
mrader
Jan 21, 2009 06:27 PM
y2kferari
Mar 28, 2007 04:46 PM
Sic_DA_Nine
Jan 8, 2007 09:54 AM
crx1856
Aug 17, 2003 04:28 PM
