Integra Running Super Rich - SEARCHED
Old May 15, 2011 | 05:07 PM
ryan_1014's Avatar
Default Integra Running Super Rich - SEARCHED
ok i have a 93 DA, pretty stock motor. was running super rich smoking blue, then it ran good for a day, now it is running rich again, wont rev past 3000, tons of blue smoke and gas smell
ive tried,
different injectors
different gas
changed the fuel pressure regulator (had an aftermarket one)
checked most of the sensors to make sure they are good map sensor etc.
throwing cel 16, not sure if thats because its missing or what
Old May 15, 2011 | 05:14 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Integra Running Super Rich - SEARCHED
This is the Civic forum.
Old May 15, 2011 | 05:24 PM
ryan_1014's Avatar
yes and more people read it then the integra forum...
Old May 15, 2011 | 05:32 PM
98civdx's Avatar
Master Detailer
Blue smoke is not fuel, it's oil.
Old May 15, 2011 | 06:25 PM
Former User's Avatar
^this
Old May 15, 2011 | 07:29 PM
94EG8's Avatar
Seagull Management
Thread moved to the Integra section.
Old May 15, 2011 | 09:02 PM
el crapitan's Avatar
cel code 16 is fuel injector.
what i'd do is start the car. hop outside and pull each spark plug wire one by one until you find which cylinder is missing (whichever cylinders plug you pull that doesn't make a difference in running condition)
then, check for injector pulse at that cylinder
Old May 15, 2011 | 10:30 PM
EJ1_CRIS_909's Avatar
x2
If ur blowing blue smoke and smelling fuel, u got 2 problems.
Old May 16, 2011 | 12:23 AM
Integra4lyfe069's Avatar
im just smelling fuel.
running rich
where do igo now?
i replaced fuel filter, replaced oil and cap and did tune up rotor plugs etc
shouldnt need to change wires cause their 2 year old ngks but only ran on them a year.
any ideas?
i thinking my 02 might be out
Old May 16, 2011 | 03:51 AM
jAyee124's Avatar
head gasket?
Old May 16, 2011 | 07:29 PM
Old May 16, 2011 | 11:11 PM
ryan_1014's Avatar
figured it out... bad ecu... put in a p28 virgin and it ran fine
Old May 17, 2011 | 10:44 PM
yes. because the injectors ground through the pcm
PoorManR_CRX
Jan 21, 2014 09:27 AM
Mik3
Jan 26, 2006 06:35 AM
StolenTeg
Jun 22, 2004 07:21 PM
91glassycrx
Feb 22, 2004 01:38 AM
live4speed
12
Sep 1, 2003 08:46 PM
