Starting issue
Old May 14, 2011 | 11:13 PM
munchlax's Avatar
Default Starting issue
I have an all stock 91 honda civic dx hatchback. every time I go and start the engine when the engine is cold, it takes a while for it to crank over and start. But when the engine is already warmed up, it fires right up. Anyone know what this may be?
I have new spark plugs and wires and also new belts. maybe its the distributor?
Old May 15, 2011 | 09:55 AM
fcm's Avatar
fcm
Old Fart
Default Re: Starting issue
Explain "crank over", are you saying engine cranks, [turns over] slowly, as in a problem with starter motor, or do you mean it just will not fire, [start] as easly as when already warmed up? 94
Old May 15, 2011 | 03:27 PM
munchlax's Avatar
yeah it turns over and wants to start but it wont fire until like 30 seconds. and when the engine is warmed up and i turn off the car and then it fires up like a normal car.
maybe bad timing?
Old May 15, 2011 | 04:11 PM
fcm's Avatar
fcm
Old Fart
Engine coolant temperature sensor maybe. it could be running rich.
Try this, [with cold engine] turn ign. to run, wait for fuel pump to stop running, [priming] then try and start the car, if it does not start right away stop cranking the engine just before it starts, immediately remove spark plugs and see if they are "wet" with gas, do they smell of gas?
Inspect the condition and color of the plugs, let me know.
If engine starts before you stop cranking, let it run for a few sec. and turn it off, immediately remove and inspect condition and color of plugs, let me know. 94
Old May 16, 2011 | 05:46 PM
munchlax's Avatar
no gas smell and no discoloration, they're new plugs
Old May 16, 2011 | 06:43 PM
BoRiCuA's Avatar
2 things are needed for the car to start, fuel and spark that's it. check dizzy maybe rotor is loose, if not check gap on plugs. from their call a friend and swap dizzy's to find out if it's the distributor before you go spend your money
Old Jun 16, 2011 | 05:21 AM
BiGZ's Avatar
main relay if no fuel 99.5% of the time (do you hear the fuel pump priming? if not,search main relay repair + re-solder or get another @ JY),or bad dizzy if no spark...
Old Jun 16, 2011 | 06:40 AM
D16SiHatch's Avatar
3 things. you forgot timing
sprtbiker
Oct 15, 2009 05:57 AM
bb608901
Feb 4, 2007 08:19 AM
RacerXintegra2k
Jan 28, 2003 07:37 AM
datbuoylex69
Dec 13, 2002 06:28 AM
Bklyn TSi
May 23, 2002 08:29 AM
