HELPPPPPPPPPPPPP MAJOR BRAKE PROBLEM
Old May 14, 2011 | 02:08 PM
jofat91's Avatar
Icon3 HELPPPPPPPPPPPPP MAJOR BRAKE PROBLEM
HELPPPPPPPP I HAVE NO BRAKE PRESSURE AT ALL...
I TURN ON THE CAR STEPP ON THE BRAKES AND IT HITS THE FLOOR I TURN OFF THE CAR STEP ON THE BRAKES THE PEDAL GETS VERY HARD... I CHANGED THE M/C AND BRAKE BOOSTER ... I BLED THE BRAKES .... AND NOTHING
IF U HAVE ANY SUGGESTIONS PLEASE TEXT ME THEM 2014679221
Old May 14, 2011 | 05:34 PM
caeavesRSX-S's Avatar
Default Re: HELPPPPPPPPPPPPP MAJOR BRAKE PROBLEM
Did you bench bleed the master cylinder before installing it?
Old May 14, 2011 | 05:37 PM
http://www.youtube.com/watch?v=_VMXC2xsy2s
http://www.ehow.com/video_2327999_be...-cylinder.html
Old May 14, 2011 | 10:37 PM
delsolo95's Avatar
check valve on booster...
Old May 14, 2011 | 10:40 PM
Linked's Avatar
the valve on the booster is most likely working because the booster appears to work
if he didnt bench bleed the master cylinder BEFORE putting it in, then he has a ton of air in the system now and has to bench bleed and rebleed the MC and system
4DoorCivic1
Jun 4, 2012 08:43 PM
Ueichi
Feb 25, 2011 02:25 PM
pedroa06
Sep 3, 2009 06:23 PM
Harleyfxdl80
Oct 1, 2006 05:20 PM
LAKER HATER
Oct 22, 2005 01:33 PM
