Anybody know anything about swapping a JDM D15b
Old Sep 30, 2002 | 02:45 AM
Touch's Avatar
Default Anybody know anything about swapping a JDM D15b
Does anybody know what I need to do wiring wise to drop this motor in? Is anybody running this setup if so is it a powerful sohc motor?
pre-thanks
Old Sep 30, 2002 | 08:24 AM
poison's Avatar
Default Re: Anybody know anything about swapping a JDM D15b (Touch)
it would depend on what wiring harness you use.
it's just the same as wiring up a regular Z6 motor
Old Sep 30, 2002 | 01:21 PM
Touch's Avatar
The swap candidate is a 92 cx. I heard that they are wired for vtec, but is that from the firewall to the ecu or the whole thing?
Old Sep 30, 2002 | 02:10 PM
eg6ajk's Avatar
yes jdm d15b (VTi version) is a VX block with a P08 (d16z6) head, ECU used is P08
as far as 92 cars they were wired from the shock tower connections (plugs) for vtec
anyways its only 2 wires for vtec (plus one chassis ground), also USDM will need their )2 sensor chenged to 4 wire if using P28...but if you are using P08 JDM VTi ecu one wire 02 is standard there...so no need to change it...
Old Oct 1, 2002 | 09:00 AM
Touch's Avatar
Default Re: Anybody know anything about swapping a JDM D15b (eg6ajk)
thanks guys
92_hatchcx
Feb 9, 2011 10:51 AM
Dukie432
30
Mar 31, 2009 04:37 PM
xxghettothixxx
Jun 29, 2007 04:03 AM
yusoslo
Apr 19, 2004 09:47 AM
stangkilla
Dec 7, 2001 08:02 PM
