Valves louder after valve adjustment
Old May 13, 2011 | 06:22 PM
wolf95's Avatar
Default Valves louder after valve adjustment
My buddy got his type R head torn apart and cleaned at a shop but they did not adjust the valves. I adjusted the valves before we got it started to .007 for both intake and exhaust because the haynes repair manual said .006-.007 for intake and .007 and .008 for exhaust. So I took the happy medium and set them all to .007. We got it started up but the valve tick was louder than when he got it. So we waited 2 days to tear the head apart because we also had to retorque the ARP head studs. I rechecked every valve but this time adjusting the intakes to .006 and exhaust to .008. I double checked clearances on every one and double checked tightness of the adjuster nut. We fired her up and it's louder than before.
Now, I did notice some writing on the ends of the cams. I don't know if stock ITR cams come with them or if it's a regrind and they added them. It seemed the higher pitched valve tick went away but now there's a lower pitched valve tick if that makes any sense... My buddy couldn't hear the tick while he was driving before but now he definitely can. and at Idle, it'll act like a valve is stuck open when the muffler will suck in for a sec. Any ideas??? thanks
Old May 13, 2011 | 06:28 PM
itr#1334's Avatar
Default Re: Valves louder after valve adjustment
Did you adjust the valves when the motor was cold?
Old May 14, 2011 | 06:01 AM
wolf95's Avatar
yes I did. the bottom end was a little warm though.
Old May 14, 2011 | 05:31 PM
rhd_integra_r's Avatar
bone cold for valve adjustments = no problems... make sure the feeler gauges are in good shape as well... are you following the firing order 1-3-4-2 and measuring between rocker and cam lobe?
Old May 14, 2011 | 06:57 PM
Aesthetic Gains's Avatar
Dos Pupusas
This...
Any stock cam motor should have the lash adjusted at 0.006" intake and 0.007" exhaust.
Old May 14, 2011 | 10:17 PM
wolf95's Avatar
yes, I was measuring between the rocker and the cam lobe.. I've done this with many D series before but this is my first B series valve adjustment. maybe the motor was just still too warm. I'm pretty sure I went in that order. does it really matter what order you do it in as long as the lobe isn't depressing the valve??
when he gets back from drill we're going to try it again at 0.006" intake and 0.007" exhaust.
Old May 14, 2011 | 10:42 PM
kingofbattle909's Avatar
get the "Go-No Go" feeler gauges. do your adj 1st thing in the morning after your car has had a goodnights sleep. srsly though
Old May 15, 2011 | 06:55 AM
Yes, use the timing marks on the cam and rotate 90deg for each cyl starting at TDC(UP mark) 1-3-4-2. if not you will get undesirable results it may feel like its loose but the cam lobe may slightly closer than it should be causing you to increase the clearance.
Old May 16, 2011 | 09:09 PM
wolf95's Avatar
hm. Never would have thought it'd matter. Thanks. Just waiting for both of us to get the free time to redo it...
thewrai6th
Jan 20, 2010 05:00 PM
PARADOX_sf
May 16, 2008 04:45 PM
alexisthemovie
May 13, 2007 06:36 PM
Footwork
12
Jun 14, 2003 01:41 AM
LoudAccord
Mar 25, 2002 02:05 PM
