b18b1 bouncing idle
i just bought a 96 integra ls. the last owner blow the stock ls and bought a cheap b18b1. at an idle it either stays high at around 3000rpm or bounces around 2000rpm. im not good with diagnosing engine problems so where should i start?
thanks.
thanks.
A quck google search could have got u an answer. Clean the iacv, check the fitv, and look for vaccum leaks.
Edit::
Also make sure your cooling system is properly bled
Edit::
