side mount broke off! fixable?
Old May 12, 2011 | 07:10 PM
92db2gs-r's Avatar
Default side mount broke off! fixable?
has anyone experienced their side mount breaking off? i just bought this 92 integra with a b18c1 swap and the driver side axel kept ripping so i checked it out and noticed that the motor was sitting at a angle i took off the cover and found metal shavings. i noticed that somebody heel a coiled the block and now their a half inch chunk of the block missing on top the left bolt. both bolts were completely stripped so i tried putting a new bolt on the right side and it wouldnt tighten. is it possible to get it welded and retapped?
Old May 12, 2011 | 09:59 PM
javierb14's Avatar
Default Re: side mount broke off! fixable?
I have seen that happen. You should be able to weld it and then drill and tap it. I fixed a cracked AL trans case years ago by having it welded back together and braced. The case held up fine too...the gears are another story lol.
Old May 12, 2011 | 11:34 PM
92db2gs-r's Avatar
would i be able to get it welded with the pistons and rods still in block?
Old May 13, 2011 | 12:43 PM
javierb14's Avatar
not sure, you might want to find a welder that has repaired a block before and get their take. I know that it takes a decent amount of heat to run a bead on a chunk of cast AL.
DCTegg
Aug 23, 2009 12:00 PM
grjp1988
Sep 28, 2008 05:08 PM
ayougo
Jul 1, 2006 11:02 PM
VtecKiDD
Welding / Fabrication
May 8, 2005 03:15 PM
gsrcivic619
Apr 8, 2004 05:30 AM
