94 heat issue
bought this just as a daily to get here and there.. it had heat for the first day or two.. now it doesn't? when i slide the climate control from cold to hot it will get warm then quickly fade out.. both hoses off radiator are hot.. could it still be the thermostat ??
Stock Engine?
Check the coolant level in both the reservoir and radiator. Top off if necessary. Then bleed the cooling system.
Bleeding the cooling system may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
needaimport
Jul 3, 2005 05:40 AM
PDXHatchback
Nov 24, 2003 07:27 AM
