D series Manifolds questions! Help please
Old May 12, 2011 | 03:03 PM
Team_Insane's Avatar
Default D series Manifolds questions! Help please
I own a 2000 civic hatch and I still have my d16y7(non vtec) in it n my friend is gettin rid of his car and asked if I wanted his intake manifold and exhaust manifold. And his motor is a d16z6(vtec). Question is will the parts fit my car?
Thanks!
Old May 12, 2011 | 03:30 PM
apexi_rsx's Avatar
Default Re: D series Manifolds questions! Help please
both will fit but the IAT sensor is different and u would need to ignore it. his z6 would have a 2 wire IACV and since u have a y7 u have a 3 wire IACV mounted on the TB. sometimes putting z6 manifolds on y7/y8 heads the coolant area tends to leak because the z6 has a big square like hole and the y7/y8 have a small round hole and sometimes it doesn't seal up rite. your best bet would to be to find a automatic y8 manifold if u want to upgrade. as for the exhaust manifold u would need to rework ur exhaust as you would be moving the catalytic converter under the car and not on the header. and u would need to cut ur exhaust and have a flange put on to connect to the cat. this would require a exhaust shot. all in all neither are worth ur troubles. if u want to upgrade these things buy aftermarket. ur not gonna net any gains noticeable from either.
Old May 12, 2011 | 05:10 PM
Its a skunk 2 intake manifold
Old May 12, 2011 | 06:20 PM
apexi_rsx's Avatar
could have specified that in your original post. yes the manifold will fit but as i stated before u have a 3 wire IACV and the z6 had a 2 wire IACV. you would need to make a plate to block that off . a flat 1/8" thick piece of metal with holes drilled in it to mount it and go to a hardware store and get some gasket material. cut a small piece to cover the 2 holes in the back of the manifold and tighten it down that should seal it up good with no leaks. is the exhaust manifold aftermarket too? if so u could install it but u will need the catalytic converter too then u will need to cut ur exhaust and put a flange on to meet the back of the cat. if u do this does he have his old stock parts to replace what ur taking? ur y7 manifold will not work on his car
Old May 12, 2011 | 08:12 PM
Sorry about that and thanks! And I'm wondering if a d15 stock intake manifold would work? The d15's that originally fit into the hatch
Old May 12, 2011 | 08:25 PM
apexi_rsx's Avatar
all d series flanges are the same
civicawesome
15
Jan 27, 2013 10:36 AM
slikz714
Feb 25, 2010 10:33 PM
jahasiel
Mar 24, 2007 02:49 PM
si937
13
Dec 15, 2006 02:18 PM
crxgator
Dec 5, 2004 01:21 PM
