Honda S2000 Honda S2000
s2000 turbo valve help
Old May 11, 2011 | 06:09 PM
datsun71's Avatar
Default s2000 turbo valve help
im rebuilding my head, what kinda of valve do i use for turbo.....dish or flat....
my goal 450whp
garrett gt3582
44mm wastegate tial
50mm bov
log pfab mani
precision intercooler
3mm head gasket
aem ems
walbro 255 fuel pump
supertech valve train
thanks
Old May 11, 2011 | 06:47 PM
HondaKyle's Avatar
Default Re: s2000 turbo valve help
stock would be fine but why are you saying you have supertech valve train?
Old May 11, 2011 | 08:42 PM
dagle's Avatar
You should call Supertech and/or your engine tuner. For 450whp, both dished and flat will work fine.
Old May 13, 2011 | 02:52 PM
gentek1145's Avatar
STOCK valvetrain is suitable up to 600hp with many people currently doing this.
Old May 17, 2011 | 05:19 AM
White Smoke's Avatar
i my honda
Global Mod
For a turbo build you 100% want dished valves! However, there is nothing wrong with the stock dished valves for your power goals.
Flat valves are generally designed to raise compression (and are also a few grams heavier) and are intended for NA builds on Honda's. The Dished valve in and of itself is a MUCH better design for these motors.
Old May 19, 2011 | 10:00 PM
datsun71's Avatar
thanks guy, i bent my valves on my s2000 f20c that why im rebuilding my head with supertech valvetrain...dish valves is the way to go then...
i heard the stock retainer on the f20c is weak.
eurolicious
Honda S2000
Jun 10, 2013 10:38 AM
dc2turbo
Dec 21, 2005 04:25 PM
cxVtecC1
Nov 5, 2004 06:18 AM
Slick GS-R
Apr 3, 2002 01:57 PM
