Car only goes into gear when engine is off? Loose clutch pedal
Old May 11, 2011 | 02:29 PM
mr_munro's Avatar
Default Car only goes into gear when engine is off? Loose clutch pedal
GSR
Cannot get the car into gear whilst driving (needed a tow) but car will go into gear when it is off. Fluid level was low, but top up only solved the problem for a short time (few miles)
What does it mean? Slave cylinder?
Thanks
Old May 11, 2011 | 03:50 PM
thewrai6th's Avatar
Default Re: Car only goes into gear when engine is off? Loose clutch pedal
Bleed the slave and check the travel for the clutch fork. If the fork is working, you might have a busted spring on the clutch disk, seizing the clutch to the flywheel/pressure plate.
Trying to force it into gear will destroy your synchros.
Old May 11, 2011 | 04:00 PM
mr_munro's Avatar
Ok thanks!
Old May 11, 2011 | 05:00 PM
94VTEC2TONE's Avatar
been there, good luck man
Old May 12, 2011 | 05:00 AM
creed86's Avatar
If there's no pressure in the clutch then more likely than not its something with the hydrulics. Check under your clutch and see if you can see the piston from the cmc leaking.
Bleeding the cmc should temp fix it. Likr the others suggested bleed the cmc and check the smc. Changing the cmc is pretty simple. I used the write up from TI. Good luck hopefully its nothing more serious
Old May 12, 2011 | 11:48 PM
mr_munro's Avatar
All fixed...the clutch master cylinder needed replacing!
jwshilli
Jul 14, 2009 03:02 PM
96 EX
11
May 15, 2009 10:29 AM
Hemix
11
Jun 30, 2008 11:25 AM
snzh22
Apr 29, 2008 09:22 AM
Nick248
May 29, 2002 07:28 AM
