blown fuse 15 (you already know)
Old May 10, 2011 | 04:46 PM
John Hencock's Avatar
Default blown fuse 15 (you already know)
Hey everyone, just joined today and BEFORE you flame. I have been reading on issues about the common culprit of blown fuse 15 (under-dash) 7.5 AMP fuse. I AM STUMPED! I removed my Intake Manifold bracket, looked around for any sign of corroded, burnt, and/or chaffed wires. I found NONE! I even taped the C115 Harness wires just in case. I've run out of ideas guys, could you help me on anything?
just some things I thought you might want to know which may help solve the problem...
The only thing(s) I have done to the car is change the HU, but even after I changed it, no CEL or anything..this was 1 week ago. (it was a custom HU, but I switched it out to a better one).
2 days ago: Right BEFORE the CEL came on, I was driving around testing the power of v-tec and gunned it a bit. I was really thinking there had to be burnt wires somewhere (heat dissipating off the car, from me revving and gunning it), but I could not find anything. I've gone through 5-6 7.5 fuses trying to figure out the problem. Any suggestions/thoughts? It would be highly appreciated.
its a '96 honda civic ex 150k miles in case you were wondering
Thanks!
Old May 10, 2011 | 04:50 PM
Former User's Avatar
Default Re: blown fuse 15 (you already know)
Check for an exposed power wire for one of the O2 sensor heater elements.
Old May 10, 2011 | 05:32 PM
apexi_rsx's Avatar
+1 i had the same problem in my rsx and it happen to be the power wire arcing off the chassis from my downstream o2 sensor.
Old May 31, 2011 | 06:21 PM
PuR_HART's Avatar
what did u discover?
b20ek
Apr 6, 2010 12:23 PM
craigers2k
Nov 15, 2009 08:17 PM
JDMtype Eg6
Dec 4, 2005 09:51 PM
97VtecIN
Dec 1, 2004 07:07 PM
willymac22
Mar 9, 2004 09:38 AM
