96 ek coupe w/ 99-00 Dash swap, HOW TO INSTALL AND GET AC TO WORK???
So i just picked up a 96 ek coupe, and the guy did a 99-00 dash swap... i have no idea why -_-. I recently picked a 99-00 center bezel and plugged everything in, the heater works so thats good.
to my knowlege the 96-98 temperature are cable controlled where as the 99-00 are electronic. NOW.. i want to get ac working,
its a d16y8 swap, everything is missing, the lines and everything.
What parts would i need to get and wiring and everythang? or is it same for 96-00?
Thanks
Thanks
no ac system, no lines at all, juss a bare d16y8 tranny and some power steering.
so only a 99-00 ac parts will work? a 96-98 will not work?
well i guess thats logical, although the chassis is 96, the dash has been converted to a 99-00, i hope the guy who did the dash swap, hooked everything up...
as for wring differences, other than where it plugs to the bezel, the fan motor plug is different and the rear window defrost wire has to be spliced into the main harness
its no longer in the car. if your swapping to a 99-00 center bezel you have to change the heater core box too (or just the bottom control parts). it is electronically controlled
hmm it seems my heater and fan is working already so i guess that isn't a problem right now, so i juss need to get the ac in and recharged and i should be set? also does anyone know which exact parts i need? i find ppl selling their "complete" ac systems, but i'm a noob when it comes to ac, what are the exact parts needed? lines, condesor, canister etc.
lines, condenser , compressor,belt, A/C Accumulator/Drier,A/C Evaporator ,A/C Expansion Device....i have almost eveyrthing but a few things like condenser but i have the stuff that goes under the dash,lines,a/c compressor everything but the condenser...let me know if ur intrested i can send a pic if u want. all of this is from a 97 civic
but someone local selling it complete for 50$... he juss took it off his car.
sounds good... goodluck to ya.. shippin woulda been a bish anyway lol... just like to help out those that are lookin and not looking to buy brand new oem parts.
btw u running a d16 turbo in ure ek?
yes i had a stock z6 with the edelbrock turbo kit on 10psi. after 2 yrs it eventually spun a rod bearing. so im in the process of droppin a z6 eagle/wiseco build very soon. as soon as i finish this chasebays brake line tuck and shave the engine bay and paint it. i already built the motor myself last month.
i was probably making near 200hp as u see in my sig i ran a 14.7-14.6@97-98mph. this was only a basemap from phearable.net and was never tuned. i don't plan to tune it until i get my new build in it and actually make some real power. i wasnt too worried about blowing the stock z6 but my basemap was a pretty good tune. i did run a wideband and afr's were within the range. which would be about 200hp in a 4dr. when u boost ur y8 it will be the best investment u can make. i love having a ball bearing turbo and having full boost by 2500-3k rpms. i can say it was the best money ive ever spent and enjoy every penny of it. if u ever need any help or have questions u can Pm me.
Thanks
Thanks
96-98 to 99/00 dash and heater unit conversion
hi bro hi have a few questions about that conversion, i delete the heater, can be make the conversion only the ac?
If you return OP, please respond here:
https://honda-tech.com/honda-civic-d...rsion-3260464/
Old thread locked.
Old thread locked.
iheartmyej8
Jan 10, 2007 06:47 PM
greenmonster
Apr 3, 2004 03:42 PM
FritzInTN
Jan 24, 2003 01:43 PM
