car wont start
Old May 9, 2011 | 11:52 PM
JDM_95_LS's Avatar
Default car wont start
Well we just got done putting a new turbo in my buddys car. We got a new starter on it car started twice then went to try and start and it didn't start. Check the fuse changed the postive wire. Now can't figure out what the problem is.
Old May 10, 2011 | 05:33 AM
Former User's Avatar
Default Re: car wont start
Starter doesn't crank, right? Is the battery dead?
Old May 10, 2011 | 11:57 PM
JDM_95_LS's Avatar
batterys fine got it recharge couple days ago
Old May 12, 2011 | 10:48 PM
JDM_95_LS's Avatar
ttt need the car running by this weekend.
Old May 13, 2011 | 03:48 AM
moddedright's Avatar
Check grounds, espcially on the transmission and thermostat.
Old May 13, 2011 | 04:20 AM
rollinkhutis's Avatar
Check the ground to the tranny... Might be loose or unbolted and you can't see it do it IC piping.
Old May 13, 2011 | 06:46 AM
Sonia's Driver's Avatar
Don't assume that the battery is "fine" just because you got it charged at some point in the past. You'll need to measure the battery voltage when the ignition is at "off", "on", and "start" to provide more information about the status of the battery.
Please describe your symptoms in more detail. What happens when you try to start the engine? Does is crank or does it just click?
Old May 13, 2011 | 07:45 AM
JDM_95_LS's Avatar
Doesn't crank or clicks
Old May 13, 2011 | 07:48 AM
frankenghia's Avatar
use a mulutimeter and check for voltage at the "start" wire on the starter. When you turn to start you should get voltage. If not, go from there.
Old May 13, 2011 | 07:57 AM
Check the rubber stopper at the top of the clutch pedal.
Old May 13, 2011 | 08:08 AM
good point Ron..
Old May 13, 2011 | 10:17 AM
If it clicks, I would rule out the clutch interlock.
I think that your most likely problem is your battery. Have you tried a jump start? If that doesn't work, try jump starting with your battery disconnected.
If that doesn't work, it's possible that the new starter wasn't installed very well. Double and triple check that install job - any loose wires?
Old May 13, 2011 | 12:21 PM
Old May 13, 2011 | 02:58 PM
pinoy85's Avatar
check the wires to the starter.
Old May 16, 2011 | 12:11 AM
JDM_95_LS's Avatar
well couple days ago i went to check if it'll crank, and it did. started fine for a couple days then last night it didn't crank anymore. the car has an alarm with a remote start. would that possibly be an issue?
Old May 23, 2011 | 09:06 PM
JDM_95_LS's Avatar
bump
Old May 24, 2011 | 07:18 AM
Dude, we gave you a whole bunch of things to check that could possibly be an issue.
Did you check any of them? If you don't add more info, we can't narrow down the list of possible causes.
Please don't bump a thread if you aren't going to do the checks because we won't be able to help. If you can't do the checks - or don't want to, just take it to a mechanic.
Old May 24, 2011 | 07:43 AM
If you can't hear it click check the main relay.
barnchips
Jul 19, 2013 11:34 AM
FLA$HY_5SiX2
Nov 8, 2011 02:57 AM
JDMdb8isO
Feb 6, 2011 12:58 PM
jonnybadboi9
Jan 31, 2007 11:16 PM
85civic
Sep 15, 2004 04:55 PM
