cylinder hone question
Old May 9, 2011 | 02:10 PM
EF-ingB16's Avatar
Default cylinder hone question
i bought new pistons and rings so i need to hone the cylinders to put them in and i was wondering if i need to remove the crank to hone the cylinders. If i don't need to remove the crank then what precautions should I take so i don't damage anything. The engine in still in the car so if there is anyway to do this without taking the engine out that would be great.
Old May 9, 2011 | 03:02 PM
Str8EJ's Avatar
Default Re: cylinder hone question
Even if you could prevent the honing stones from touching/damaging the crank, I'm not sure how you could prevent metal dust from falling on the crank journals. It would be a nightmare trying to clean the block after honing it.
I think the crank, at the very least, has to come out.
Old May 9, 2011 | 03:13 PM
EF-ingB16's Avatar
wow that sucks. i don't suppose there's a way to do that without taking the engine out of the vehicle.
Old May 9, 2011 | 03:33 PM
Aesthetic Gains's Avatar
Dos Pupusas
I honed my engine while it was on the car. The motor is still running. It's all about the prep work.
Old May 10, 2011 | 07:22 AM
Str8EJ's Avatar
^ Crank wasn't removed?
What sort of prep work did you employ?
I think that's the sort of detail the OP is looking for.
Old May 10, 2011 | 07:47 AM
DDTECH's Avatar
Get a honing tool from matco or snapon.
Get a good drill and lube up your cyl walls with motor oil or WD40 and go up and down in a smooth, but steady motion, allowing for the rough up of the cyl walls.
I find 20-30 seconds per cyl wall is a nice time to spend honing out.. After your done, spray some wd40 again and clean the walls nice and neat...removing all of the honing mess.
I've personally used this method on cars that have came to me and do not wish to be bored out, just rehoned, and we also use this method here @ porsche / audi for rebuilds.
wtf_is_jdm
Mar 14, 2018 09:41 AM
hoffdaddy
Jan 26, 2015 08:40 AM
boostnubII
Nov 8, 2006 10:25 AM
impr323
14
Oct 9, 2005 08:32 AM
Louie
Sep 11, 2002 06:02 AM
