b20vtec or poorman's?
my current poor man's set-up!
wanted to know if i should go b20vtec for more power!!!
b16a head.
rc 310 injectors
port&polished.
buddyclub spec III cams.
buddyclub retainers.
buddyclub valve springs.
skunk2 camgears.
hytech replica header
itr manifold/ str 68mm TB
hondata manifold gasket
b18c1 block
ls crank
shot peened ls rods
ctr pistons
ys1 tranny
b16a head.
rc 310 injectors
port&polished.
skunk2 camgears.
b18c1 block
ls crank
shot peened ls rods
ctr pistons
ys1 tranny
Car's craving for a bigger set of cams. I believe a better set of cams would keep you set on your poorman setup rather then going through such a change.
if he's refering to a poormas type R, wich I think he refered, then he got it wrong...people just say a poorman's type R to a B18C1 shortblock + R pistons + stock b16 head...if that changed...I dunno...
Just get better cams + a better intake manifold...that should do it...
what exhaust are you running ? and Ecu Engine management are you tuned or getting tuned ?
Because a performerX is a better manifold for 1.8's..
and blox cams, because they are cheaper?? pro2's would surely do fine for this setup.. there's alot of cam options out there.. you need to do alittle reading in the 1.8 liter dyno thread.
I agree with the Pro 2 cams, and a port-matched/polished professional product intake manifold. I threw one on and it made a world of difference. I just need cams, a valve train, and 3" intake tubing now...
Angel4768
May 9, 2011 12:49 PM
komat
29
Jun 30, 2009 06:47 AM
deftones0817
Jul 15, 2004 05:48 PM
