EP3 shaking at 40mph and above
Old May 5, 2011 | 03:14 PM
808DA's Avatar
Default EP3 shaking at 40mph and above
I have a friend with a 04 SI. He says that his steering shakes when he turns and drive at speeds above 40 mph. What could be causing this? Would a bad axle cause this to happen? Thanks!
Old May 6, 2011 | 04:35 AM
turboteg2nv's Avatar
Default Re: EP3 shaking at 40mph and above
It could be lots of things.. is the suspension modified? Does it need an alignment? Are the tires balanced correctly?
Axles usually click when turning and that's how you know they are bad.
Old May 6, 2011 | 05:29 AM
DaveSi677's Avatar
Pretty much sums up all the questions that needed to be asked and answered!
Old May 6, 2011 | 05:17 PM
square_1's Avatar
x2
Get under the car and start inspecting stuff visually. Also you can jack the car up and by shaking the wheel side to side or up and down you can check for ball joint and tie rod end play.
Old May 8, 2011 | 06:43 AM
WhiteOnRice's Avatar
Slightly off balanced wheels can cause a bad shake if in combination with worn struts. Check his struts as well (push down on car hard; it should come back to regular height without oscillation).
Old May 9, 2011 | 09:09 AM
mustclime's Avatar
lets not forget a bent wheel and or a tire out of round.
Old May 9, 2011 | 03:06 PM
808DA's Avatar
thanks for all the suggestions. i will let him know all these so he can check it all out. he did try to get an alignment but the shop told him to fix the axles. im not sure if its the axle cause there are no sound when turning etc.
Old May 9, 2011 | 08:58 PM
What do they claim is wrong with the axles?
Acurazor
Suspension & Brakes
Jun 26, 2009 08:47 AM
acuralovar
Jun 20, 2009 11:38 PM
94eh2
Feb 14, 2007 04:52 AM
black sohc civic
Jan 24, 2005 02:27 PM
shortyz
Mar 29, 2003 03:36 PM
