Old Mar 31, 2015, 03:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
Print Wikipost
alarm keeps going off middle of night
Old May 4, 2011 | 10:14 PM
phoxking's Avatar
Default alarm keeps going off middle of night
my alarm keeps going off about every 4-5 hours only at night..so basically when i'm asleep.. anyways could someone tell me how to fix this? my doors are always closed i checked it's not a cat or anything hopping on the hood.
oh and i just have some regular alarm from falcon..believed same co. as viper?
Old May 5, 2011 | 03:52 AM
0c00l's Avatar
Default Re: alarm keeps going off middle of night
If you don't have a proximity sensor then it's your vibration or shock sensor. It just needs to be set properly. I'm not familiar with Falcon (if it is) http://www.falcon-security.com/about.php I would go under the dash and see if you can see the module or the shock sensor it should have a small dial on it to set it with. I would start turning it in small 1/16 inch increments counter clock wise and each time you do this, shut your door roll up all windows and set the alarm. Kick your tire or use your fist balled up and lightly tap the driver side window until it goes off. It shouldn't be that easy to set off. Keep doing it until you get it to a point where it's kinda hard to set it off.
Old May 9, 2011 | 04:50 PM
AChickInACivic's Avatar
my boyfriends old 4 door Ek did the same thing, we could never figure out why.
Old May 9, 2011 | 06:12 PM
0c00l's Avatar
I have had a few alarms (DEI, viper, clifford) do this back in the day 90's. We found voltage fluctuations due to bad ecu on GM trucks and once on vw that would cause the alarm to go off every so many minutes. There also has been bad alarm modules that has caused this. If it's under warranty, have the shop look at it or if the parts are then get them swapped out.
Old May 13, 2011 | 03:48 AM
NVturbo's Avatar
O.G. triple O.G.
DEI DOES NOT make "FALCON" alarms. Sounds like an off-brand to me. If it does go off randomly, lessen the sensitivity on the impact sensor. If the alarm does not have adjustments, replace it....the alarm I meant.
Old May 13, 2011 | 04:23 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Get rid of that alarm. Thats your biggest issue. There all are like that after awhile. Falcon is the crappiest alarm you can get.
Old May 18, 2011 | 06:43 AM
EJ1_CRIS_909's Avatar
Some1 is tryin to jack ur car at night :p
Old May 18, 2011 | 08:18 PM
FTNW's Avatar
some theifs will test your alarm , or maybe testing you to see what you do .. i would stay on my toes
Xxcivic99xX
Honda Civic (2006 - 2015)
Feb 24, 2008 05:55 AM
importpower94
Dec 2, 2004 08:27 PM
98prelude98
Audio / Security / Video
Sep 21, 2004 02:00 PM
