Suspension & Brakes Theory, alignment, spring rates....
air ride
Old May 4, 2011 | 06:36 AM
Pharaoh's Grim's Avatar
Icon2 air ride
so ive got an 89 si with a low body kit and im tired of scraping on driveways nd massive speed bumbs. i was thinking of getting an air bag suspension. ne1 have 1 or seen it done?
Old May 4, 2011 | 07:38 AM
spencerskate93's Avatar
Default Re: air ride
Please don't.
Old May 4, 2011 | 07:51 AM
9WON4's Avatar
Remove body kit - Cheaper more hetero Solution,
Old May 4, 2011 | 08:39 AM
its not even just the body like my down pipe and cat scrape. at stock height. we are talkin sum massive speed bumps
Old May 4, 2011 | 10:01 AM
TheAsian's Avatar
Riderite makes some of the best kits I've seen. I would Sug check-in them out
Old May 4, 2011 | 01:39 PM
T_S_S's Avatar
I would stay away from air cylinders at all cost. They have HORRIBLE ride quality and they tend to leak after a short period of time.
Air Struts are the best.
Old May 7, 2011 | 06:21 AM
psychoboy's Avatar
if you run quality cylinders and install them properly, they'll last forever.
problem is, nobody ever installs them correctly, so they end up leaking at the seals.
my 3rd gen prelude was on cans, and ride was excellent at all heights unless it was locked up (which was taller than stock). those cans are on their third car now, and they still perform excellently.
the only cans i would run are from SMC. any of the cans from AIM or MIC (at least, what they used to sell) are too poorly constructed to use on a daily driven car.
but, just like any other airride suspension. INSTALL is the most important part. and i don't think i've seen half a dozen properly installed airride kits on hondas in my life.
airstruts have their place, and they are better than they used to be, but i still don't trust a rubber bag in the environment of a honda front suspension.
Old May 8, 2011 | 10:36 AM
cooldeal man thanks ill check em out.
Old May 8, 2011 | 10:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Keep in mind that alignment changes with EVERY ride height change.
So unless you plan on aligning the car weekly, don't go around changing the ride height weekly unless you want your tire wear to suck donkey *****.
Civic_07
20
Dec 4, 2008 02:17 PM
92CivicSIRhb
Suspension & Brakes
Sep 14, 2005 05:33 PM
stingray2772
Jan 15, 2003 05:55 AM
ILLA_00LS
Oct 18, 2002 07:36 AM
