VTEC Activation
Old Sep 29, 2002 | 03:56 PM
SIRBUSH's Avatar
Default VTEC Activation
I have a B16A1 that i just swapped into a 91 civic, I was wondering how you can tell if your VTEC is kicking in, i cant hear any change in tone? What should happen different, should there be a big change in sound with this motor?
Old Sep 29, 2002 | 05:02 PM
Kamin's Avatar
Default Re: VTEC Activation (SIRBUSH)
you will know when its on.
here.
https://honda-tech.com/zerothread?id=164863
Old Sep 29, 2002 | 07:48 PM
KURRRRWA
Guest
Posts: n/a
Default Re: VTEC Activation (KAMiN)
I have a B16A2 and the VTEC kicks in at 5600 rpm. It doesn't get louder, but the tone changes. If you have a stock intake, it's really hard to hear.
Old Sep 29, 2002 | 08:36 PM
Kamin's Avatar
Default Re: VTEC Activation (SD99Si)
mine sounds like the world is comming to the end.
Old Sep 29, 2002 | 09:32 PM
VtecApprentice's Avatar
you are a damn funny fellow . . . you sounds funny in your every post and even your pic of the Homer Simson is funny
Old Sep 30, 2002 | 12:15 AM
miller's Avatar
Default Re: VTEC Activation (VtecApprentice)
run a test light to the vtec wire and see if it is getting the signal!!
Old Sep 30, 2002 | 04:28 AM
AussieK24's Avatar
Default Re: VTEC Activation (vtecdoc)
Take you intake hose off and go for a run around the block....You'll know hehehe
Old Sep 30, 2002 | 04:42 AM
miller's Avatar
Default Re: VTEC Activation (b16a4me)
no dont do that!!
Old Sep 30, 2002 | 05:18 AM
JALOP B16's Avatar
Mine kicks in at 5k w/stock pr3 why??????????????????
Old Sep 30, 2002 | 05:19 AM
JALOP B16's Avatar
Default Re: VTEC Activation (JALOP B16)
And yes im sure its at 5k rpm I watched it carefully and it does ....
Danielsb20crx
24
Jul 5, 2009 01:37 AM
tomcool
May 14, 2007 07:21 PM
usdmike
13
Jul 3, 2004 08:21 PM
Wave
Aug 1, 2003 06:04 PM
vincent97gsr
Jan 28, 2002 10:55 PM
