MSD removal questions - Help!
Old May 3, 2011 | 07:28 PM
99SlammedCivic's Avatar
Snipper Snapper
Default MSD removal questions - Help!
Hey guys,
The R has an external msd ss blaster that is run to the dizzy inside the cap.
I decided to remove it and replace it with a new dizzy just because.
When I installed the new dizzy, the car doesn't even attempt to start. I tried another dizzy off another R of mine and that did the same thing.
I then re-installed the original dizzy w/ the external blaster and the car started right up.
With the new dizzy, the car doesn't even attempt to start at all.
It does have an alarm on the car but I"m not sure if that has anything to do with it.
Also, I did not see the MSD box anywhere in the car.
Suggestions?
Pictures:
Old May 3, 2011 | 09:39 PM
Snipper Snapper
Default Re: MSD removal questions - Help!
I"m also getting code 8 which is the TDC code which suggests getting a new dizzy.
Help
Old May 4, 2011 | 10:03 AM
1998GsRIntegra's Avatar
So did the car crank when you installed a factory dizzy or just nothing?
If the car did crank, did you verify firing order and check to see if you had spark on all cylinders?
Just a couple thoughts
Old May 4, 2011 | 10:49 AM
Snipper Snapper
Didn't even crank
Old May 4, 2011 | 06:13 PM
Snipper Snapper
Yelllooowwww
Old May 5, 2011 | 10:47 AM
Snipper Snapper
Old May 5, 2011 | 01:22 PM
omiehomie's Avatar
Originally Posted by 99SlammedCivic
i got some leads for you pimpin
http://www.msdignition.com/forum/showthread.php?t=4664
http://www.msdignition.com/instructi...pdf?terms=6200
Old May 5, 2011 | 05:21 PM
94rs-turbo's Avatar
he's having the reverse problem.
Im stumped on this one, just make sure the wires going to the dizzy to the engine harness match up
Old May 5, 2011 | 05:57 PM
R boy fresh's Avatar
Very weird issue.. but its good your getting rid of that msd coil.. had the same one a few times in previous builds and found that its problematic .. definitely better off with stock ignition .. good luck hope you get it figured out
Old May 6, 2011 | 12:09 PM
Snipper Snapper
The wires are in the right order - I double checked - I may look at it again today.
Old May 8, 2011 | 09:07 AM
Snipper Snapper
Old May 8, 2011 | 08:22 PM
Snipper Snapper
Any other thoughts?
Old May 8, 2011 | 08:31 PM
xero_xero's Avatar
the blaster is just the coil. another dizzy should work properly.
i give you ignition help.
http://techauto.awardspace.com/ignition.html
99SlammedCivic
May 10, 2011 04:03 PM
nitewolf
Oct 26, 2009 04:53 AM
black2001ITR
Feb 11, 2009 07:44 AM
StreetFusionR
May 7, 2007 01:14 PM
AudioXtremes
Sep 5, 2002 07:57 AM
