Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Honda Civic
Old May 3, 2011 | 03:50 PM
arcadiaz1's Avatar
Icon2 2001 Honda Civic
Can someone explain to me how to take off the exterior driver side door handle and key ensemble?
Old May 3, 2011 | 04:12 PM
EM2abe's Avatar
Default Re: 2001 Honda Civic
Probably from the inside.
Old May 3, 2011 | 05:48 PM
lazlong's Avatar
Yeah, once you take the inner panel off it should be pretty obvious.
Old May 3, 2011 | 05:51 PM
01_civic's Avatar
its pretty obvious but unless u get the rods off and away from the locking assembly..your'e ****ed. I couldn't get the rod off the handle when i was replacing the lock actuator...its a bitch...but goodluck.
Old May 3, 2011 | 06:50 PM
arcadiaz1's Avatar
I got the two bolts off 10mm, and took off a two plastic washers and a metal one and it still aint coming off.
Old May 3, 2011 | 07:20 PM
It Wasn't Me's Avatar
There's a retainer clip (looks like a bent piece of coat hanger) tucked behind the bracket that the cylinder mounts to. Have you removed it? You can access it just beneath the cylinder. Pull it down to remove it.
Then just pull the handle up, and out. (like you're opening the door)
Jakester9500
Mar 1, 2012 12:00 PM
handa
Sep 28, 2010 04:32 PM
BoBo Racing
May 22, 2009 06:46 AM
Rudaluda
Mar 1, 2006 09:29 PM
clutch33
Feb 1, 2004 01:40 PM
