Transmission & Drivetrain Gearboxes, Differentials, Clutches
GSR TRANSMISSION HELP
Old May 2, 2011 | 11:15 PM
Jdmefsir12's Avatar
Default GSR TRANSMISSION HELP
OK I GOT A LIL ISSUE HERE...... I GOT MY CAR WITH A B20 TURBO IN IT WITH A GSR TRANS.... SHIFTED LIKE BUTTER... I SWAPPED MOTOR TO B16 WITH SAME GSR TRANS AND NOW FOR SOME REASON I HAVE A LOT OF PLAY IN SHIFTER WAT I MEAN BY PLAY IS I CAN GO AROUND IN CIRCLES WITH IT LIKE I AM STERRING SOMETHING...... 1ST GEAR IS FINE 2ND GEAR IS FINE 3RD GEAR WONT GO IN JUST GRINDS...... BUT BEFORE I COULD DRIVE BEFORE 3K I COULD PUT IT IN THEN ALSO I COULD GET IT IN AT HIGH REV.. NOW SHIFTER HAS GOTTEN WORSE NOW I CANT GET 3RD AT ALL... SO I DONT KNOW WAT THE HELL HAPPEN....
CAN ANYONE HELP ME.. IF I DONT MAKE SENSE LET ME KNOW AND ILL TRY TO MAKE IT MAKE SENSE THANKS
Old May 2, 2011 | 11:16 PM
Jdmefsir12's Avatar
Default Re: GSR TRANSMISSION HELP
ALSO WHEN CAR IS OFF IT WONT GO IN EITHER...........
Old May 3, 2011 | 07:55 AM
Honda Bull's Avatar
WHAT DID YOU DO WITH THE SHIFT LINKAGE AND STABILIZER BAR WHEN YOU PERFORMED THE SWAP?
DID YOU SWAP FLYWHEEL AND CLUTCH OVER TO THE B16 OR DID THAT COME WITH A CLUTCH/FLYWHEEL YOU DIDN'T TEST YET?
Old May 3, 2011 | 12:03 PM
Jdmefsir12's Avatar
IT HAS A NEW 6 PUCK SPRUNG CLUTCH AND A STAGE 5 PRESSURE PLATE DUAL PLATE AND A 6 POUND FLY WHEEL ALL FROM ACTION CLUTCH AND ALL NEW... WHEN I DID SWAP I TOOK IT OFF TRAN AND IT WAS ON FLOOR...
Mihopopvtec
Nov 27, 2018 01:44 PM
Mokunui
Oct 27, 2017 12:00 AM
xlusiveracer
Apr 3, 2017 09:53 AM
acuracy90
Aug 27, 2003 03:58 PM
ronman92
Apr 17, 2003 08:26 PM
