92 Civic CX/JDM B16 - fuel injectors not working (solved)
Old May 2, 2011 | 03:03 PM
Eric724's Avatar
Default 92 Civic CX/JDM B16 - fuel injectors not working (solved)
first off for who dont know i have a 92 cx with a jdm b16a the problem that iam having is iam getting fuel to the fuel rail but not to the motor i tried 2 diffrent injectors and still nothing i check the ground wires what should be the fuel psi and how do i check it second question is the fuel pump i know it works i can here it kick on when i turn the key is there anyway to check it to see if it working right
Old May 2, 2011 | 04:37 PM
Former User's Avatar
Default Re: fuel questions
Do all four fuel injector clips get voltage with the key in ON(II)?
Old May 2, 2011 | 05:09 PM
Eric724's Avatar
Default Re: 92 Civic CX/JDM B16 - fuel injectors not working
i just check it not getting power can some post up the pin on p30 ecu for the fuel injectors
Old May 2, 2011 | 05:36 PM
Start by checking whether fuse 31 or 24 is blown.
Old May 4, 2011 | 05:09 PM
Eric724's Avatar
i think i figured out why my car woln't start i checked everything the fuses the main relay and i even tried diffrent injectors so i was thinking that the ecu was bad but i took it to a friends house and put it in his car and it started up so i tested the wires on the injectors and nothing so iam pretty sure that somewhere the wire to the injectors got ****ed up so iam going to pickup a nother wiring harness tomorrow
Old May 4, 2011 | 05:26 PM
tlarimer's Avatar
Did you check the ground on the thermostat housing?
Old May 7, 2011 | 03:19 AM
Eric724's Avatar
well i got the car started and its running fine and not throwing any codes the reason it wouldn't start was my dumb *** forgot to plug on of the caps back on the wires on the driver sider there is a bundle of wires that look like they are caped off but its really a circut thanks for all the help guys
Old Nov 26, 2013 | 12:08 PM
codyorr82's Avatar
Default Re: 92 Civic CX/JDM B16 - fuel injectors not working (solved)
Ive got a 92 teg with a b20 and having some what of the same problem, ok so ive had the car for a few days and ran fine up until yesterday, it would start just fine then just crank over, ive got spark, replaced the main relay after finding out my other one was fried, still will just crank over, fuel pump is on a switch and dose work, if I spray starting fluid in it will start and run for a few seconds then die,
I could really use the help as I am new to imports
bubba cola
12
Mar 3, 2009 05:00 AM
mikester1222
17
Apr 18, 2008 07:32 PM
slamedcivic
Nov 2, 2006 01:49 PM
90civSi
Jun 22, 2006 12:23 PM
shreddinryguy
Jun 26, 2005 01:28 PM
