What kind of pistons will fit on pr3 rods
Old May 2, 2011 | 01:48 PM
D.Rex's Avatar
Default What kind of pistons will fit on pr3 rods
like title says i have a b16a3 with pr3 rods....what kind of selection do i have?
Old May 2, 2011 | 02:01 PM
94EG8's Avatar
Seagull Management
Default Re: What kind of pistons will fit on pr3 rods
What exactly are you going for here? High compression? Low compression?
Old May 2, 2011 | 02:46 PM
D.Rex's Avatar
High compression
Old May 2, 2011 | 07:22 PM
D.Rex's Avatar
tttt
Old May 2, 2011 | 07:45 PM
D.Rex's Avatar
tttt
Old May 2, 2011 | 07:58 PM
Wdpfreak145's Avatar
Dude, don't bump your thread 20 minutes apart. First of all, makes you look like a douche. Second of all, if someone has an answer, they will post it. Otherwise, just wait or do more research.
Old May 2, 2011 | 10:43 PM
GoSickemRobert's Avatar
id get aftermarket rods if you are trying to get aftermarket pistons... unless you just want to interchange oe rods and pistons
Old May 3, 2011 | 01:04 PM
D.Rex's Avatar
tru...dont the oem type r's fit?
Old May 4, 2011 | 07:22 PM
D.Rex's Avatar
maybe i should just sell them pistons and buy a built b20 block
Old May 4, 2011 | 07:25 PM
94EG8's Avatar
Seagull Management
Yes.
Old May 4, 2011 | 07:55 PM
SOHCNightmare's Avatar
I'll second this...
No sense in doing this half-way. Do it right the first time and you'll not have to mess with keeping a hacked together build in one piece.
Old May 5, 2011 | 09:32 AM
D.Rex's Avatar
tru...my boys looking for a set of eagles for me hope i get them soon....ill probly sell that block and get a b20 block and just build the hell out of the b16 head...
Old May 5, 2011 | 09:34 AM
D.Rex's Avatar
thanks for the help
Old May 5, 2011 | 10:18 AM
Old May 5, 2011 | 10:45 PM
teamjdm239's Avatar
nippon ctr pistons would be a cheap alternative. and they will fit on pr3 rods.
Old May 6, 2011 | 03:39 AM
Deetz's Avatar
Crazy Honda Guy
Unless you plan to run high boost, there is not really any need to change out your rods. Even just a set of ARP rod bolts should be all you need.
As far as OEM pistons go.....
- ITR pistons have "less" compression than PR3's
- CTR pistons are high comp, but the dome is so high, you often don't get a complete burn
- my choice would be the jdm 2nd gen b16 piston.....the P30
Old May 6, 2011 | 05:19 AM
TaffetaEj6's Avatar
x2
Old May 7, 2011 | 08:49 PM
D.Rex's Avatar
no pr3 rods dont fit the nippons i brout them to the machine shop there clearance issue where piston meets rod
Old May 9, 2011 | 11:05 AM
D.Rex's Avatar
bump
Old Jul 23, 2011 | 03:44 PM
EF-ingB16's Avatar
well i bought the ycp ctr pistons and they dont fit on the pr3 rods i have and it sounds like the same problem as the nippon pistons. is there any way to machine a small amount of material off the end of the rods to make them fit into the nippon or ycp pistons? its only about 2.5 mm too big.
Old Jul 23, 2011 | 03:46 PM
grumblemarc's Avatar
The Grumpiest
That doesn't sound like a little bit of material to me.
Old Jul 23, 2011 | 05:16 PM
EF-ingB16's Avatar
Ya I'm not an expert or anything that's why I was asking if there is any way it's even possible to take off that much material. I'd like to know what the max amount I could take off if any.
Old Jul 23, 2011 | 11:23 PM
Deetz's Avatar
Crazy Honda Guy
ctr pistons are terrible, sell them off and buy some p30's, they will fit with no mods
BlkChryKord
Nov 6, 2006 11:35 AM
vteghatch
May 16, 2006 06:37 PM
jakscivic
Sep 13, 2005 11:19 PM
spun Vtec
Oct 25, 2004 08:15 PM
specie
Dec 8, 2002 09:42 PM
