what 2 do now?
Old May 2, 2011 | 12:59 PM
974drgs's Avatar
Icon6 what 2 do now?
i have a 94 civic coupe w gsr swap, sk2 intake manifold,sk2 68mm throttle body, stock header, 99 si exhaust, all new sensors tps,map,o2, air intake temp,and egr valve. anyways running real rich and smokin black soot, and burning oil. did a compression test and was 235 across the board, and gettin around 16-17 mpg. Im lost on what 2 do next?
Old May 2, 2011 | 01:03 PM
TaffetaEj6's Avatar
Default Re: what 2 do now?
bad thermostat will cause a motor to run rich
burning oil will either be rings or valve stem seals
Old May 2, 2011 | 01:12 PM
974drgs's Avatar
ok thanks ill check thermostat next
Old May 2, 2011 | 01:14 PM
TaffetaEj6's Avatar
post update as well
Old May 2, 2011 | 01:33 PM
BlackCivicEX's Avatar
change name of thread,
Old May 2, 2011 | 01:47 PM
Former User's Avatar
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post.
Andrew7447
Aug 12, 2012 03:09 PM
.I.Need.Money.
Jul 18, 2006 04:49 AM
jdmdc2110
Jan 28, 2006 10:48 PM
Grandprix
Oct 10, 2003 05:53 AM
92slowvic
17
Jul 23, 2003 04:50 PM
