I know this is the wrong place, but I am totally at a loss, and need help badly ....
Old Sep 29, 2002 | 02:20 PM
TypeR0207's Avatar
Default I know this is the wrong place, but I am totally at a loss, and need help badly ....
After all the years of knowing/talking to everyone here, I'm hoping at least one of you may know where I should start to figure out my problems doing this install:
https://honda-tech.com/zerothread?id=293046
Old Sep 30, 2002 | 05:32 AM
TypeR0207's Avatar
Default Re: I know this is the wrong place, but I am totally at a loss, and need help badly .... (TypeR0207)
No one has any suggestions????
Old Sep 30, 2002 | 06:10 AM
JPP's Avatar
JPP
Did you check to see the error code before you reseted the ECU ? . That could direct you to the possible problem.
Old Sep 30, 2002 | 07:04 AM
EVIL CETANE's Avatar
LOL, dude switch your MAP wire and your TPS wires, I think they are on wrong, I know this happens to integra's when they are on backwards. They are the only 2 connector the fit eachother and they are right next to each other
Old Sep 30, 2002 | 07:12 AM
Dave-ROR's Avatar
Default Re: I know this is the wrong place, but I am totally at a loss, and need help badly .... (cetane)
posted your opinion and my agreement in the st00k thread.
One thing that strikes me as weird.. in the s2k forum thread typer0207 said you can't check codes like in tegs, accords, civics, just about every other newish honda I've ever worked on.. that seems too weird for me.. and I don't quite believe it..
Old Sep 30, 2002 | 07:53 AM
reefer_bob's Avatar
Default Re: I know this is the wrong place, but I am totally at a loss, and need help badly .... (Dave-ROR)
I'd be very shocked if that was true. OBDII is the same no matter what. I have this neat little code reader that I plug into the OBDII jack under the dash. It tells me the code, and can then erase them with a simple push of the button. Sears!! Very handy tool.
Old Sep 30, 2002 | 09:33 AM
dohcsideSi's Avatar
i have done this once before w/ the same exact results...although i didn't get a check engine light!! check everything from the computer to injectors to the distributer to the wires....those damn plugs are exactly the same!! i'll never make that mistake again
Old Sep 30, 2002 | 11:55 AM
TypeR0207's Avatar
Default Re: I know this is the wrong place, but I am totally at a loss, and need help badly .... (dohcsideSi
Sweet! Good call, I'll check them again .....
What I mean about not reading the codes is that on the Teggies and Civics, the CEL will blink accordingly for you to know what the code is wiothout hooking up anything special to read the ECU. Or on the older models, you have the red blinking light on the ECU itself ............
Old Sep 30, 2002 | 12:57 PM
TypeR0207's Avatar
On the way from work to school (where I am now) ....... I thought to myself ...... "You never even touched the TPS and MAP sensor leads inside the engine bay, right??"
I'll double check them when I get home tonight, but I am still running it over to Autozone in the morning and getting the code checked .......
da9blk1
Sep 3, 2007 11:47 AM
O16581724 5 2 5
Nov 16, 2005 09:10 AM
Crasian
Jul 15, 2005 08:00 AM
skrewdlude
Mar 5, 2003 08:08 AM
This One
Feb 2, 2003 04:20 AM
