Rod Bearing stuck on crank!
Old May 2, 2011 | 06:40 AM
Bizzle5OH3's Avatar
Default Rod Bearing stuck on crank!
Hope this is the right forum! So I picked up a B16 that was bare except for the crank. The block had a spun rod bearing, you can see were the bearing kinda "molded" itself to the crank, just a little spot. My question is, can a machine shop smooth this out for me and make the crank usable or should I not waste my time and just get a new one? If Im forced to get a diff crank what would you guys/girls on here recommend for a tuboed B16? GSR crank, B16 crank, type R, LS?
Old May 2, 2011 | 06:50 AM
kyden's Avatar
Default Re: Rod Bearing stuck on crank!
get a new crank. you can't put anything other than a b16 crank back in it without using custom parts.
Old May 2, 2011 | 06:51 AM
LordAphotic's Avatar
its going to be cheaper to just find another crank. usually spun bearings happen from lack of oil or extreme overheating or both. so theres a chance the crank itself is also warped. but even if its not it will be way cheaper to get another crank.
Old May 2, 2011 | 09:03 AM
Bizzle5OH3's Avatar
Alright, thanks for the advice
hatchet_honda
Nov 6, 2009 08:26 AM
som1dies
Dec 16, 2006 05:06 PM
NXSpoon
Jan 10, 2004 03:13 PM
scrambledeg
Dec 14, 2003 10:52 PM
carcala
Apr 14, 2002 12:24 PM
