Check Engine light for 02 Sensor
Old May 1, 2011 | 12:35 PM
EKdriverin703's Avatar
Default Check Engine light for 02 Sensor
Here is my current dilema. I have a 1998 Honda Civic Hatchback with a B20B swap I got a CEL and its throwing a code for an upstream O2 Sensor malfunction the O2 sensor is brand new so I dont understand why it would be throwing a code. I let the car run for a bit drove it around thinking would open the sensor up and that didnt work I also unplugged the battery for five minutes that also didnt work. I checked the voltage on the wires and its getting power from the ground and everywhere else. The O2 sensor is for a 96-98 Integra im thinking that maybe I have the wrong one? A few of my buddies said that I could have the wrong ecu as well which is an OBD2LSa. Do you guys have any ideas or any other suggestions I can go about solving this issue? Any help would be greatly appreciated.
Thanks in advance guys.
Old May 1, 2011 | 02:06 PM
Default Re: Check Engine light for 02 Sensor
no one can help me out?
Old May 1, 2011 | 03:19 PM
j4s0n1337's Avatar
I have the same issue with my 95 hatch b20b swap. What ecu are you using? I have a obd1 pr4 ecu and that requires a 4 wire o2 sensor, I found a guide on how to wire it somewhere on here but it still doesn't work, so I'm curious about this as well.
Old May 1, 2011 | 03:31 PM
I have an OBD2LSa ecu and its also a 4 wire to the O2 sensors......This is keeping me from getting my emissions which means I cant drive my car
Old May 1, 2011 | 03:37 PM
j4s0n1337's Avatar
I was supposed to get mine inspected back in February but I'd fail with the CEL on
Old May 1, 2011 | 03:53 PM
yea bro it sucks *****! My car has been sitting in the driveway since March
Old May 1, 2011 | 04:41 PM
j4s0n1337's Avatar
Well what ecu are you using? That'll tell you what o2 sensor it runs off of, I.E. what o2 sensor you'll need to install
Old May 2, 2011 | 03:36 AM
obd2lsa...is their anyone out there that can help a brother out!?!?1
Old May 5, 2011 | 07:21 AM
figured it out....
back2basics
May 25, 2010 05:46 PM
the.hamburglar
Jul 13, 2007 05:49 PM
boosted111EG
Jul 5, 2007 07:42 PM
DreamSpeed
Jan 13, 2002 11:29 PM
scrubachu
Jul 30, 2001 04:24 AM
