93 civic DX planning 96 gsr swap - which ecu?
Old Apr 30, 2011 | 11:37 AM
chikichimo's Avatar
Default 93 civic DX planning 96 gsr swap - which ecu?
Hello all! I am new here and so far it's been more informative than any other forum I've found. Period.
All of my questions have been answered but one that I couldn't find in the FAQ's page.
Here is my situation:
I have a 93 dx civic and I am swapping in a 96 gsr powerplant soon. I have the gsr harness and ecu, but I hear obd2 ecus are horrible.
Would I be able to just chip my dx ecu? Or will I need a vtec ecu? I looked for an obd1 p72, but I can't find anything for less than $150.
If I am in the wrong section or there is already a post on this, please direct me. I couldn't find one. Thanks for any info guys!
Old Apr 30, 2011 | 11:48 AM
grumblemarc's Avatar
The Grumpiest
Default Re: which ecu?
OBD2 ECUs are horrible for what? Use the ECU for the engine-OBD2 P72.
Old Apr 30, 2011 | 02:54 PM
chikichimo's Avatar
I've heard from a few sources that they can't be chipped, tuned, etc. Plus I would need a jumper harness, and an obd1 to obd2a jumper would be expensive. I might as well buy the obd1 p72 if that's the case.
Old Apr 30, 2011 | 03:02 PM
94EG8's Avatar
Seagull Management
Royal pain in the *** in an OBD1 car, and in no way worthwhile. Much easier to just get the corresponding OBD1 version or a chipped and tuned ECU.
Old Apr 30, 2011 | 03:28 PM
The Grumpiest
I saw 96 GSR but it looks like you're gonna have to bite the bullet and shell out the $150 then get it chipped and tuned. If you've already spent the money for the swap the buck fifty is chump change.
Old Apr 30, 2011 | 03:42 PM
HondaPartsHero's Avatar
Technical Hero
use your P06 and convert it to P28, contact these guys
www.xenocron.com
Old Apr 30, 2011 | 03:45 PM
chikichimo's Avatar
This is what I was talking about...lol I knew there was something wrong with them in an eg.
Would it make a difference if I chipped/tuned my stock p06 or a p28 instead of the p72?
Believe it or not I got a damn good deal on the gsr setup. :D
Old Apr 30, 2011 | 03:47 PM
The Grumpiest
I run a converted P06 to work with my Y8. You can have the same done to your ECU and have the proper basemap put on it.
Old Apr 30, 2011 | 03:59 PM
chikichimo's Avatar
Right on. I will check them out and see what I can do.
Thanks guys!
Old Apr 30, 2011 | 11:35 PM
eghatch9295's Avatar
Stancetard Hate Monger
by the time you pay for chipping/tuning, youd be out your money for a p72. look around, they can be had much cheaper than 150.
Old May 2, 2011 | 06:07 AM
xenocron's Avatar
But once chipped, he is ready for future mods as well...
You can purchase the kit to chip and VTEC your P06 ECU:
http://www.xenocron.com/combo-kit-ch...sion-p-55.html
Or we do the service as well if you would like to have it done.
You CAN find the OBD1 stock P72 ECUs for cheaper than $150 yes, but then you HAVE to wire in the knock sensor, which can be troublesome, and they are worthless IMHO
Old May 4, 2011 | 10:52 AM
chikichimo's Avatar
The only obd1 p72's I could find that weren't molested were more expensive than the services xenocron offers.
If I were to use the xenocron chipped p06, what all would I have to wire in besides vtec?
Thanks for all the info though guys. I'm not new to cars but I am new to ecu's and whatnots. lol.
Old May 4, 2011 | 02:50 PM
apexi_rsx's Avatar
not unless the p06 was chipped with a vtec chip itself. then u can wire vtec. if its just a chipped p06 and u wire vtec it will not work.
Old May 11, 2011 | 04:11 PM
chikichimo's Avatar
sorry...my question was vague lol. I meant if the p06 was chipped with vtec and the gsr basemap...what all would I need to wire up from the tower to the ecu plugs? Thanks again guys
Old Jul 17, 2011 | 07:38 PM
93gsrhatch_1's Avatar
i got the same question... what wire off the p06 runs the vss?
Old Jul 17, 2011 | 07:48 PM
Former User's Avatar
http://www.phearable.net/tech/wiring...schematics.gif
Old Jul 23, 2011 | 12:52 AM
Default Re: 93 civic DX planning 96 gsr swap - which ecu?
THANK YOU!
Old Jul 23, 2011 | 02:47 AM
NotAJDMFanBoy's Avatar
Convert the P06. You'll want to get Hondata, Chrome, Neptune, etc if you do anything more than bolt ons anyway.
If you use Hondata, you can just chip the ECU and get a couple of relays and run VTEC and IAB control off existing circuitry. No need to add VTEC.
chrisc543
Engine Management and Tuning
23
Sep 29, 2013 03:44 PM
itr1244
Apr 29, 2005 06:01 PM
fatalman
Dec 22, 2003 06:50 PM
CivicFerioSiR
Aug 25, 2003 08:22 AM
4drb18ek
Mar 1, 2003 07:42 AM
