Car starts 1/3 of the time
Old Apr 29, 2011 | 08:58 AM
FATKID87's Avatar
Default Car starts 1/3 of the time
Recently my car has not been starting all the time. I just replaced the starter and the problem still continues. Some times it will turn over when I turn the key other times when I turn the key nothing happens. It doesn't even turn over and some other times it will start then die and when I try to restart it it just turns over and doesn't start.
I drive a 5 spd '93 del sol that I bought used...
Old Apr 29, 2011 | 10:38 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Car starts 1/3 of the time
get new grounds, if that dont fix it...
when you turn the key to "on" do you hear the fuel pump prime everytime?
if you cant hear it at all. rollyour windows up. turn your radio off.
and turn the key all the way before actualy starting the motor..
you should hear a hummmm..
if you dont hear it everytime you have a corroded board on your main relay.
get a one at the junk yard.
or
you can fix it yourself.
take it out. pop the top grey or black cover off the top of it. and theres all these solder points...drop a drip of solder on each one.
Old Apr 29, 2011 | 01:48 PM
monkeybrainz's Avatar
from what u posted sounds like ure main relay it sends power to ure fuel pump as well as other things if u turn the key and nothing happens like the lights (oil,seatbelt, etc) then its a ground but if they turn on and still nothing it's more than likely ure main relay.
Old May 1, 2011 | 09:22 AM
FATKID87's Avatar
well my radio and lights all that turns on but nothing happens as far as the car truning over...
Old May 12, 2011 | 02:09 PM
FATKID87's Avatar
So it's probably my main relay I don't want to spend 56 dollars for nothing... Is there any way to check if it is to be 100% sure or no
Old May 14, 2011 | 04:27 PM
FATKID87's Avatar
ok just for the record... i couldn't hear anything when it was in the on position no fuel pump or anything over the loud beeping it does to say that the srs isn't engaged yet... but anyways so i went ahead and spent the 60 dollars on the main relay cause i had no other guesses.... did that this afternoon and it started, then changed my g/f's oil and it started up again so fingers crossed it fixed it... the bored was a lil yellow but all the solder looked fine and not cracked.... sooo who knows if it will stay fixed... will post again if it still doesn't work for more ideas thanks guys
Old May 16, 2011 | 06:13 AM
delsolintegra's Avatar
I have a 93 del sol SI D16Z6 auto all stock and have had the same problem. For the past 8 months I have been blaming the main relay and the fuel pump and have swapped them out which seemed to fix the problem and the problem came back after about a month each time. The day after a rain storm it came back again. Turns out it is the ignition switch. Next time it happens to you jiggle the key as you turn it thru the starting positions. You may hear the fuel pump kick in and then you'll know for sure. I think the electrical switch alone is available after market (ebay). The dealer sells the whole switch and key cylinder (about $250). Or junkyard.
I'm in Florida too, near the beach, maybe it's the humidity?
Old May 16, 2011 | 06:42 AM
FATKID87's Avatar
Icon6 Re: Car starts 1/3 of the time
Wow I just went out there to leave and sure enough didn't start so I guess I will try the ignition switch.... That's alot of money though...
Old May 16, 2011 | 06:48 AM
FATKID87's Avatar
Would the radio and everything still come on if it is the ignition switch?
Old May 16, 2011 | 07:30 AM
I'm not Rick!
no.
go to the junk yard and take a few main relays. and try them.
if you have a friend with a honda civic (88-00) try their main relay.
or...buy one and try it. then youl know if thats it or not.
or...i can sell you one cheap you pay shipng.
or you fix yours...check here VVV
http://techauto.awardspace.com/mainrelay.html
^^nevermind the technical pictures in it. jus drip a drop of solder on each big major point on the board
Old May 16, 2011 | 07:36 AM
FATKID87's Avatar
Originally Posted by rick_rabies
no.
I already replaced it with a new one and it still isn't working so if it was my ignition switch my radio and dash lights wouldn't come one because try are lighting up and the radio kicks on but it doesn't even try to turn over
Old May 16, 2011 | 08:03 AM
I'm not Rick!
^true. and you have checked all fuses/relays? ignition relay should be under the hood and one under the dash.
Old May 16, 2011 | 08:07 AM
FATKID87's Avatar
Icon2 Re: Car starts 1/3 of the time
Yes and it wants to start sometimes and doesn't want to others like if I wait usually 30mins to an hour it will start up
Old May 16, 2011 | 08:08 AM
FATKID87's Avatar
I am so lost right now and don't know what's wrong with my lil gremlin lol
Old May 16, 2011 | 10:22 AM
moddedright's Avatar
try checking your thermostat and tranny grounds
Old May 16, 2011 | 10:41 AM
FATKID87's Avatar
where are they
edit nevermind i found them they are fine
Old May 26, 2011 | 10:20 AM
FATKID87's Avatar
Is it possible for the car not to start due to a bad speed sensor? In my mind I don't see how that could prevent my car from starting
Old May 26, 2011 | 10:23 AM
Former User's Avatar
Sounds like a bad ignition switch.
Old May 26, 2011 | 10:41 AM
Josueneta's Avatar
same thing happens to me after i did a CRANK pulley replacement after mine fell off and then it would start like after the 5th try now its down to the 2nd or 3rd but only at the first start of the day after that its just the 1st
i check my fuel pressure gauge and its ok i think
Old May 27, 2011 | 07:31 AM
FATKID87's Avatar
Is it possible though?
blaxican05
Feb 23, 2008 08:47 PM
ef9_pr0jekt
Oct 7, 2007 06:15 PM
The Captain
Feb 26, 2007 08:08 PM
slowexcoupe
May 23, 2005 08:48 PM
