PAINTING INSIDE YOUR ENGINE BLOCK
I was wondering how many of you heard of using glyptol to paint the inside of the crank case? this paint has a coat which is very smooth and helps oil drain back down into the pan. i never seen anybody mentioning doing this after having extensive engine work done. also wanted to know if there was a certain brand people use
it was used on cast steel blocks that were rough on the inside.... honda aluminum blocks are smooth already. so its one less thing to chip off and clog an oil passage
hmmm.... i see, im pretty sure that stuff wouldn't chip off otherwise folks would not use it but i had never thought about the fact that most of these people are using iron engine blocks. its the same stuff they use on electric motors (armature specifically)
