Suspension & Brakes Theory, alignment, spring rates....
Washer trick question
Old Apr 28, 2011 | 03:52 PM
lxdriver's Avatar
Icon6 Washer trick question
So here's the thing: my car is at stock height but I still have negative camber on the rear passenger tire, so negative that its out of specs. So what Im gonna do is use the washer trick to try to bring it back to spec, the range is 0 to -2 degrees, what do you guys recommend to leave it at? 0 or between the range?
edit: its a 2000 civic lx
Old Apr 28, 2011 | 04:14 PM
JustOneOrTwoPosts's Avatar
Default Re: Washer trick question
anywhere within the spec is fine. I would tell the alignment guy to try and match it up to the other wheels' specs as closely as possible. BTW, you shouldn't have to be doing this is everything is oem. Have you checked your entire suspension and chassis for bends?
Old Apr 28, 2011 | 04:18 PM
98civdx's Avatar
Master Detailer
Your over -2* at stock height!?
Me suspects suspension damage.
Old Apr 28, 2011 | 05:15 PM
lxdriver's Avatar
Well they (firestone) usually leave the other wheels within specs but the RP tire is always the "black sheep" of the car, its always been off since I can remember. My car is salvage so that might be why or maybe the camber-arm bushing is going out, so if I do the washer trick, I'd only be doing it on that tire
Old Apr 28, 2011 | 06:11 PM
98civdx's Avatar
Master Detailer
You got larger issues then a bushing. Fix the car, don't band aid it.
I wouldn't have even touched the car if I was Firestone.
ekcivic9
Suspension & Brakes
19
Oct 16, 2007 01:19 PM
hondabigblock
Apr 30, 2006 06:32 PM
Mr. Choi
Oct 28, 2003 12:09 PM
nemesismachine
Jun 27, 2003 05:45 AM
jsi
13
Sep 5, 2002 08:25 AM
