engine swap, plus y8 intake mani on y7 question
I've been reading threads all morning and haven't been able to find an answer to these questions, so here's what I have going on:
I have a 2000 Civic LX. I have rebuilt another d16y7 engine with a block from a 98 and a head from a 96 to replace my worn out engine. (Sourcing parts is hard in Arkansas, so I got what I could.) I want to put this engine into my 2000, but with a y8 intake manifold instead.
Here's one question: Which intake manifold do I need to use? I found a 96-98 auto manifold, but it doesn't have the extra cold start assist holes. I assume that I need a 99-00 auto manifold because the wires are OBD2b, but I'm also not sure how that will affect the rest of the engine.
Any suggestions/wisdom?
99-00 d16y8 manifolds have the air assist ports in the IM that would need to be plugged to avoid vacuum leaks. You should be fine with a 96-98 auto d16y8 IM.
My 99 civic LX D16Y7 does not have it, so it's safe to say that only the D16Y8 have it.
Edit: It air injection, not air assist, had to break out the FSM.
eddies_ls88
Dec 23, 2010 09:13 PM
skate_volcom2006
Sep 3, 2008 05:12 PM
speedehatch
Dec 23, 2003 11:42 AM
fastcrxsi90
Dec 24, 2002 10:03 AM
