ABS Sensor
Alright, to my knowledge, my ABS light is on do to the senser on my rear passenger side tire. Im not to shure on how to go about fixing this. Is it possible to do it yourself and what am i gonna need if i can do it.
p.s. I did run a search, nothing on how to fix, a couple just tell you how to find out.
Thanks
Jon
Thanks
Jon
okay that mother ***** is wrong on abs sensor.
i think i know wats wrong wit ur car.
abs light is on because the abs pump on ur car run and the unit have ittermitent failure. go reset the ecm and see if the problem reoccur. if it reoccur listen for loud noise as the abs motor running. if there is loud noise, u have a abs motor problem go to the dealer have it fix.
do not mess around wit abs motor. or else u have no braking system. dangerous.
Read the text before you start calling people names, (especially someone like Chiovnidca who is a real Honda technician and good contributor to this place).
Also, you CAN work with the abs system
josh-roy
Jul 30, 2010 02:32 AM
